Hi guys, I've been wondering about how noticeable tyre roll is with the stock rims/tyres on the R33 and how much better it is with 17" rims.
Right now I'm running the stock rims with 225/45R16 (I know, yuck), I've been thiking about either putting some 205/55R16 on there for a while or going straight to the 17" rims. I wanted to know if there'd be a noticeable difference from my current set to the stock tyres. Also, anyone that's upgraded from 16" to 17" rims, how have you found the handling of the tyres changed?
Finally, if anyone has any recommendations for tyres that grip well but sacrifice longevity for lower price I'd love to hear 'em.
Cheers
https://www.sau.com.au/forums/topic/185603-tyre-roll-with-stock-tyres/
i went from a 225/50/16 on r32 GTR wheels on my s14 to 235/45/17 on r33 GTR wheels and the difference was huge.
i think this is mainly due to the offset and width of the new wheels.
with the r32 wheels it was a 205mm wide rim with 225mm tyres, whereas the r33 wheels were a 230m wide rim with a 235mm tyre
so there was less tyre movement on the rims. also the lower profile meant less flex.
definently go up to 17's when you can, save for some 8.5 or wider rims (i had 9inch wide all round) and some average 225/45/17 tyres. they will definently be better tha high quality 205/55/16 tyres.
    • Yep, replacing all those hoses is kind of just bog standard if you're ever back there. Only hose on the back of the engine I have yet to replace is a vacuum hose for the wastegate. I'll probably do it eventually but it's in such an annoying spot.
    • I was actually just planning on replacing the fourth gear parts in the gear box that I broke … like the synchro hub or cone. And any other parts I need once I open up the transmission. That a bad idea? The rest of the gears feel tight. these parts shouldn’t be too much … just the labour here won’t be cheap. Just replacing these in HK would be around 2k aud including labour.    how much is a new r33 or r32 transmission?    thanks for the good info as usual
    • I chose a bad time to buy, at the time there was no gtst's for sale in NSW and my options were qld, vic, or sa and not the greatest examples or too far out of my budget. Ended up picking this one from adelaide sight unseen and got a bit stitched up as you could expect but i dont fully regret it, its just a shame people cant be more transparent in this day and age.
    • IMO just buy a whole R33 transmission and swap the whole thing. Use a palm nailer/air hammer with a roll pin punch to drive the shifter rod end roll pins out. The rod end is discontinued so don't break it. Use gasket dressing on the OEM paper gasket instead of RTV. I personally would not pry on the shifter cover tabs, I broke one trying that instead of just smacking the side with a dead blow rubber mallet to shock it loose from the RTV the last mechanic applied. If you can't get the flanges totally clean and free of any residual RTV and/or you might have a gap that is bigger than it should due to flange damage use RTV on that surface instead of the OEM specced anaerobic sealer. Anaerobic sealer is most likely the right sealant for the job, it's just too easy to mess it up with too large a gap or bad surface prep/roughness seemingly. If you do rebuild what you have it's for a whole gearset that can take high torque. Don't bother with OEM at that point.
    • Little hose. Big hose. They're all waiting to kill the engine.
