You can use the RB25 (or maybe it was RB30) sump
User: Fatz did it a couple years back, maybe dropping him a PM?
However if you can use the 26 one, do so.
Stock/diff removed sump is by far the best way to go about it.
https://www.sau.com.au/forums/topic/185613-rb-26-rwd/#findComment-3358565
  • 11 months later...
I know it's been quite a while since this thread was active. I did a search under drivetrain for anything RB26 related to find out what is out there for the sump issue when making it into a RWD setup.
So far this is the closest thread. I've seen some pictures of a modified 26 sump that was made in Aus. for a RWD application. I was wondering if there were any dimensions or specifics that could be passed on. Or someone or a company out there that makes them. I really dont want to do a RB25 sump and modify that one personally.
Thanks in advance.
https://www.sau.com.au/forums/topic/185613-rb-26-rwd/#findComment-4122994
rb 25 and 30 sump needs work for them to fit baffles and pannel beating for oil pickup pipe..
rb26 is much stonger but needs cutting and welding I used the 26 on my conversion..
If you supply the 26 sump I can get it modded and welded for $300
https://www.sau.com.au/forums/topic/185613-rb-26-rwd/#findComment-4123279
