hey guys just wondering would there be a massive difference in performace between the Nismo diff from the GTR compared to my stocker viscous? i heard that a standard GTR unit is apparently better than the standard GTST ones but still concerned about how much bite there is thats keeping the two apart?
looking to go for a lsd upgrade to a 2-way but still pondering about whether this is a real 2-way mechanical type (being a nismo [not sure if they made standard 33 gtr lsd's] or simply a GTR lsd) or if its not really worth the money to get one..
thanks for your help in advance!
Dom
https://www.sau.com.au/forums/topic/185619-nismo-r33-gtr-diff/
The std gtr diff is just a std nissan mechanical diff. Very similiar as to what was in the old turbo 300zx's and r31's coupes.
The nismo's are an aftermarket item. Unsure but the N1's etc 'may' have been released with the uprated nismo diff centre.
A gtr diff won't bolt up due to its different half shaft bolt up; 6 vs the gtst's 5. To get it to fit you need bolt up the gtr hubs and purchase the axles etc. So not a cheap exercise BUT you will be provided with a near bullet proof rear end should you decide to run some decent slicks with big rpm launches at the drags.
Cheapest way out.. Grab a 1k kaaz unit from one of the sponsors and have it fitted in to your diff.
The clutch/mechanical diff's are much better than the vlsd's.
im so over my vlsd lol yea ive pretty much decided to go either nismo or cusco...or kaaz...wats the difference? i have only seen rebuild kits for nismo items so sorta leaning towards that..
haha it jsut seems there is so much option on the market but im leaning towards to the nismo's due to the ability to be rebuilt. im not sure about that feature with the other units...
Woudl puting in a kaaz unit still be as strong as the gtr rear end? Im thinking not?
With regards to the diff.. the Kazz is a tougher unit than the std gtr diff.
But if you are talking about the axles/hubs then no; the gtr has the larger dia. axles.
The diff is the diff the axles are the axles.
Ultimately the GTR axles/hubs + the uprated nismo centre and its as tough as it can possibly get.
From my understanding. :P
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
