hi guys,
i have excessive tyre wear on the inside of my tyres. especially on the left or passenger side of the car. what do i need to get so that my camber can be adjusted front and back? i have heard that adjustable bushes can be bought? or is it better to go for an adjustable arm? where is the best place to source these parts?
i think they said that the camber was at -2 degrees.
thanks for your help if this has been covered sum where else jus let me know thanks
https://www.sau.com.au/forums/topic/185623-camber-adjustment/
FRONT: I'd recommend adjustable upper arms. I used the JJR dog-bone style on my R32 GTR. They looked well made, and I had no problems with them at all. The offset bushes for the front are horrendously expensive and wear quickly.
REAR: either adjustable upper arms or offset bush kits. If going arms, you need to replace both upper arms (normally called the upper control arm and traction rod) to avoid bump steer problems.
bushes are a bit cheaper and work OK on the rear - again one bush needs to be fitted to each upper arm to avoid problems with bump steer, but don't offer alot of correction. expect about 0.75 to 1 degree of camber correction from an offset bush kit. you can use two sets of bushes if needed and put them in both ends of each arm, but by then you've paid almost as much as adjustable arms are worth - probably more if you're not fitting them yourself!
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
