Well for about 1 month, there wouldn't be any polishing action, paint too soft, but you can apply some wax.
As far as i know, you should stay clear of synthetic waxes or sealants, and go with a carnauba wax.
Reason being is that carnauba breathes, synthetic doesn't.
That was my understanding.
Hit up FI for some killer carnauba's...
Dodo is great new range of waxes available recently at FI.
Pete is pimpin' Onyx at the moment (swissvax)
Zymol has an $18,000 tub of wax if you're keen :)
  • Replies 40
Pete is pimpin' Onyx at the moment (swissol)
Zymol has an $18,000 tub of wax if you're keen :D
cheers!
  • 1 month later...
not sure if you saw my post in the D.A. thread Marcus, but i'm sooo glad you took my advice to go get your car worked on by Damian. You could travel the country and possibly ship your car anywhere in the southern hemisphere and not find a better detailer :)
It's going to look stunning :ph34r: Stage 3? And please say you're getting a coat of Royale to finish it off? Nothing like finishing with a $18,000 coat of wax :wave:
Regarding FI, i read from the members only thread, SAU members have 5% discount off his services right? The other i went, Dammo said it's only 5% off DETAILING services and not a normal wash.
Can someone from the committee clarify this issue?
Apologies for the supporter post. It is true that the 5% discount only applies on detailing services.
Sorry for the confusion. Supporter thread has been updated.
not sure if you saw my post in the D.A. thread Marcus, but i'm sooo glad you took my advice to go get your car worked on by Damian. You could travel the country and possibly ship your car anywhere in the southern hemisphere and not find a better detailer :wave:
It's going to look stunning :) Stage 3? And please say you're getting a coat of Royale to finish it off? Nothing like finishing with a $18,000 coat of wax :)
are you r34skyline?
Thanks David :). Was there the other day. He was a little shocked when i asked for the 5% discount off my wash :wave:
FI is pretty darn good.
but so is my guy...and I have seen others also - its not rocket science.
A good detail and wax will last for a long time and is worth the $$...my last Zymol applciation lasted for ages..like 10 months but my car doesnt see much sun or weather.
  • 1 month later...
Thinking of booking in here soon.
To cut a long story short, ended up stuck on a one way bush road that I couldnt reverse out of, so have minor scratches all along the side of my car from ferns and other plants >.<
Stage 3 should do the trick yeah?
Thanks for the kind words mate.
About the Zymol lasting 10months, that can't be right. Zymol Waxes are toatally organic, the natural carbauba in Royale (even with 3 coats) would last a maximum of 3 months. Even without driving the car or washing it, it would see a limited amount of time, possibly 6 months max.
Maybe the 'look' still lasts 10months later but the wax will defintely be spent.
Wax up now to protect that surface! ;)
Hope this helps, if you need anymore info let me know,
d.
Oh Yeah, I've spoken to the Cafe Manager, Elise, we will now offer 5% off all wash & detailing services at FIAB now.
Present your card when you pay and we'll deduct the 5%.
Cheers guys, thanks for your support.
Edited by DamianFi
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
