ive raced the past 5 years competitvely however taking this year off id recomend checking out some websites www.tigerkartclub.com www.nkn.com.au you will need to get yourself a practise license etc and theres a fee which needs to be payed on saturdays, other then that you should go down and watch some club day meets and open days have alook around
https://www.sau.com.au/forums/topic/185682-karting/#findComment-3359819
Thanks,
I've been to a few club day meets down at Henderson and looking at getting a 30/32mm chassis with a Rotax/Leopard. Which catergory did you race..?
I wanted to go the 100S but it seems too troublesome needing a push start all the time, I want to be able to go out on my own and do a few laps when I want without needing someone to push start me all the time. Thats why I'm going the 125's.
Cheers,
Edited by PX29
https://www.sau.com.au/forums/topic/185682-karting/#findComment-3359945
I dont know wheter clubs in your area are mostly aka affiliated but next year i know the aka is enforcing that 125 drivers have a b grade licence which means you need to have 10 races under your belt other wise you cannot drive the rotax or leopard it is a high possibiltiy of this being put into motion so watch yourself you could have a kart but not be able to drive
https://www.sau.com.au/forums/topic/185682-karting/#findComment-3359972
Didnt know about this B grade licence for 125's, is this for senior class also or only for the junior classes.?
Cheers,
https://www.sau.com.au/forums/topic/185682-karting/#findComment-3360011
How did you find push starting the kart on your own..?...or did you always have a person with you..?
Cheers,
aka affiliated of course tigerkartclub ive raced interstate to, ive raced junior heavies,clubman and as of last year clubman light however if i get back into it next year il be in clubman heavy
https://www.sau.com.au/forums/topic/185682-karting/#findComment-3360122
Cheers,
Senior classes.....lots of unhappy 125 owners out there and this is creating lots of debate. 125 class for juniors is experimental and B class. As for push starting....trial and error and easier at Cockburn as its downhill...other tracks not so easy! Clutched versions of the 100 cc engines are availaable but at a cost. Drop me a PM if you need any further advise.
Cheers,
Michael
https://www.sau.com.au/forums/topic/185682-karting/#findComment-3360488
I am looking at selling my BMax with rebuilt 125 leopard as I just don't have time to use it anymore. Also have a 3 Kart side opening trailer but the setup will not be cheap.
Comes with Kart stand,Mychron 4 with data logging, spare rims, sprockets etc.
Send me a PM if you want to discuss prices.
Cheers
Ken
https://www.sau.com.au/forums/topic/185682-karting/#findComment-3367077
karting is great fun. best tip is to start out in the mid range karts and work your way up. the 125's are pretty punishing to start off with but it all depends on your size and background.
but give kartmart a buzz.. my parter Megan is the one behind the counter and she should be able to help you with your karting needs.
hurricane kart club is a good club to join as they dont charge members for practice use (except club runs etc) unlike the others.
also, for those with 125's, shifters and opens once every three months or so there will be meetings down at collie, contact kartmart or cockburn kart hire regarding this, the next one is at the start of december from memory. This is great fun as you get to max your kart out around most of the track :)
pics from the last event: http://picasaweb.google.com/shaunorman/KartingCollie
Shaun
https://www.sau.com.au/forums/topic/185682-karting/#findComment-3377071
10 meetings before you can run a rotax in seniors? aw man, here goes my plans for shits and giggles karting fun when i have some cash spare to buy one
denver, yeah it sucks.. whats even worse is from memory (very bad right now, got out of hospital 2 days ago) is that I think they are getting rid of practice/recreational licences!!! :)
Shaun
https://www.sau.com.au/forums/topic/185682-karting/#findComment-3377111
lol i havnt been racing this year and when i go up to the track not being rude to anyone but i see alot of amateur drivers or how id like to say bush bangers ppl who just buy a kart and go for a thrash, the amount of accidents this year is alot more then the past 5 years of my karting life, i dont belive ppl who are starting out should race a leapord or rotax ive been to some meetings this year and i know them classes are full now however less then half know how to drive properly and safely
https://www.sau.com.au/forums/topic/185682-karting/#findComment-3377144
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
