  • Replies 47
bump, still have the engine and the other stuff listed in the first post available!
I sent you a p.m. but I didnt get a reply. I need a power antenna, charcoal canister and the front piece of the right side inner fender liner. I'm in the U.S. but these are small pieces and should go into a box and ship with no problem. Let me know. Thanks.
does the diff have the ABS sensor connect to it ? if so il take it. please PM me your details and il come for a drive to sydney next week to pick it up.
Thanks
