I know its a long shot, but i thought i'd post it up anyways, im tryna sell my daily to get an new car, either r32/33, s14/15, stagea, gtir or somthing like that, so if someones after a good reliable daily and wants to swap plus up to about 15k, let me know, cheers
Item: 1999 Nissan Pulsar Plus Sedan
Website: Carsales Link
Item Condition: Engine, driveline and interior A1, Body and paintwork good, some trolly dints and scratches, nothing major, never been in accident
Reason for Selling: Gettin another skyline or s15 or the likes
Price and Payment Conditions: $6,990 will sell cheaper without subs and amp if desired, will swap for skyline r33/32, s14/15, stagea, gtir etc plus cash if someone wants a daily
Extra Info:
1999 n15 nissan pulsar plus
12 months rego
Air conditioning
power steering
keyless entry
4 spd automatic
fuel injection
economical 1.6L motor - over 500km's per tank
160,xxx km's
pioneer cd player
2 x pioneer 12" subs in sealed carpeted pioneer box
4x100w RMS Jaycar Response amp
kenwood and clarion speakers
clean and mark free interior
comes with factory bonnet and headlight protectors
Log books
I have owned this car for 9 months and in that time i have never had a single problem with it, im only selling it to upgrade.
This would be a perfect first or 2nd car for someone who wants a reliable, economical and overall cheap car to run, paint has some scratches and shopping trolly dints but nothing major.
feel free to call or sms me on 0407217325 at anytime and ill do my best to get back asap
Price is Negotiable
Pictures:
More pictures available on request
Contact Details:
Mob: 0407217325 if i dont answer mobile im more then likely at work
work no: 0265832364
Home no: 0265841069
Edited by Satanic_R33
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
