I just purchased a pfc for a r33 and installed it all working good execpt its not displaying the speed on the hand controller is this normal? Has anyone else had this problem? did a search but came up empty handed.. dash speedo is working ok however i just installed the amec 300km/h kit and was hoping to check the accuracy of the speedo with the pfc. any help will be appreciated.
https://www.sau.com.au/forums/topic/185738-pfc-speed-signal/
when you say its not displaying the speed, do you mean
a) it shows the speed on the hand controller display at 0km/hr at all times
b) there is no indicator of km/hr on your controller display?
if its a) i cant help you, but if its b) you just need to set it to display the speed :thumbsup: i havent touched my controller in ages so cant tell you step by step but its simple.
ok the speed diplayed on the pfc handcontroller doesnt move from 0 km/h I have changed the cluster for another one as my tacho was dead but I changed it for another 33 turbo one but thats all I can think of been the problem
"The PFC speed signal is from the gauge cluster so it won't read any differently."
to install the 300k dials you have to pull the needles off and put them back on i want the pfc to display speed so I can check I put them on in the right place
Edited by SevenAngryPenguins
Ok hope this solves it for ya, i had a similar problem. If you still have the speed signal wire connected to the Power FC (wire #53) then it should work for you, just disconnect the battery and connect it back up again after a few mins (you can open a door or pump the brakes a few times to get rid of any power still going through the car). This should do a full reset and hopefully your Power FC should display speed again.
Does your HICAS light come on after a few mins of driving?
pretty sure its connected, wire 53 is "Hicas Diagnostic wire/speed limiter" speed limiter worked with stock ecu
i took my hicas light out when I changed the cluster as im going to remove it shortly (lockbar) and didnt want it glowing maybe i will stick the bulb back in
I'll try a battery disconnect/drain, what exactly am I resetting hi-cas computer? its such a pain in the ass getting to my battery with the stereo mounted to the back board....
replaced hicas bulb and yes it does come on after a few minutes driving and heavy steering too how long did you disconnect for I did for like 20 seconds while the headlights were on but still had the problem. will disconnect for longer this time
cheers
if the hand controller is displaying 0kmh then it dosent have a speedo signal or its scrambled
typical such instances would be smoeones installed a speed cut device and hacked the wiring
or someone has cut wire 53. nothing else would cause this so check wire 53
dont bother with the hicas shit, we know wire 53 is cut, so focus no that
dont bother draining the battery, will achieve a big fat zero
Not true. I have a RB25 motor/tranny in my R32 with a chopped/hybrid speed sensor in the tranny. It now has the cable output going into the dash. Even with the speedo disconected (read broken), my PFC told me how fast I was going and the speedo said bupkiss.
seems that the signal goes to the hicas for the variable steering weight then feeds to the ecu for the speed limiting function this is only a guess is there anyone with wire diagrams that can confirm this
:thumbsup:
If your keen, the pin outs will be in the service manual for your car.
ok got it working disconnected battery for half hour and is now working go figure....
I have a cap so that might of been holding a bit of charge...
thanks for all the help guys
Told ya :D
Pretty much the reason it does this is because if it has been cut and it accidently earthed out or touched another wire or something it would stopped getting a signal. When u disconnect the battery it resets the ECU and the wire gets the signal again ;) Same thing happened to me while wiring in a SAFC, accidently cut through the speed signal wire and it stopped the speed signal and because HICAS needs a speed signal to operate it malfunctions aswell.
Ahhh the joys of wiring....
neither of mine work :D
-actually the speedo works ,but only after giving the car heaps . like at a track day ... anyideas
PFC reads 0kmh
Dash reads 0kmh
Pretty much the speed signal from the gearbox goes to the dash, then it goes from the dash to the ECU (wire #53) then goes to the hicas computer in your boot. So if your dash reads 0kmh, the problem is obviously lying between the gearbox and the dash.
You said the speedo works after giving the car heaps, so maybe there is a lose wire behind the dash and when u hit a corner hard the wire is getting connected back up or something and working again. Anyway id be looking at the speed signal from the gearbox to the dash.
Hope that helps mate.
maybe I accidently shorted it putting the pfc in was lazy and never disconnected the battery because it such a pain to get in my boot, come to think of it I had a blown 'engine control fuse' what ever that is but it sure as hell made the pfc not work there was some serious clicking going on though
thanks pm-r33
thanks pm-r33
Haha, no worries champ :D
thanks pm-r33
Hmmm...
The speed sensor on a R32 takes the analog signal from the gearbox then sends that to the HICAS, ECU & Power Steer units.
the 4WD sensors are wheel mounted from memory.
Anyway, if you swapped instrument cluster, the new cluster may be working, but may have a faulty, damaged or missing speed sensor unit inside it! search for my name and speed sensor, there is a post on how to swap the sensors over, if you have the old one still I imagine you should be able to swap sensors and fix the problem in under an hour!!!
If the heavy steering and hicas problem has come about since the speedo swap this would make sense, and also stop the data going to the ECU for your powerfc, but if the problem had been there for a long time i imagine it is your loom that is damaged.
Good luck!!!
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
