Ok guys I have an update I got NRMA out to look at the car , it has fuel but no spark at all, tried swapping the green relays next to the ecu still no spark. Anyone got any ideas what could be causing no spark? NRMA guy said either my alarm system or ignitor module.
  • Replies 51
Posted Images
Hey mate sorry to hear about the incident.
But anyways, I'm in no way mechanically minded or anything (so if this seems as a ludacris suggestion meh what ya gonna do...), but something similar happened to a mate's car..... after an oil change hahahah. He would turn the key, hear the fuel line pumping, but then the engine would just keep cranking with no sparks. After hours and hours of trying to figure out what was the problem it turned out that the wires giving current to the spark plugs (don't know what they are called) were knocked ever so slightly so that it wasn't sitting on properly but seemed as if it was.
Now I don't know if your problem is as simple as this, but I guess its worth a try to see if that wire is somehow burnt or something.
Well anyways, good luck.
Rian
Have you confirmed power is being supplied to the coils? Power is feed via the ignition coil relay (one of the green relays near the ECU) to the coil packs. Disconnect one of the coil packs and check for a 12V feed when the key is switched to the "on" position. If no feed is present you will need to check the source of the supply.
The relay is feed power from the thick white wire with purple stripe. You can check the power feed easily at the connector near the power steering reservoir. Turn the key to the "on" position and you should have 12V at this wire. While you are at it, check for 12V at the white wire with black stripe (feeds ECCS relay which then feeds power to CAS, MAF etc).
Once you have done this let us know how you go.
Cheers
Ok guys I have some great news to report, tried my mates ignition module from his GTR and boom it started first go, put my old one back in just to make sure that was the problem and it wouldnt start so it was the ignition module :w00t:
Car is running like a bit of a pig tho keeps wanting to stall at idle or when you come to a stop but im guessing this could be because it has had the same fuel in it for 4 months and has been drivin less then 50km since June.
Thanks for everyones help!
DONT connect your battery around the wrong way!
Also if anyone is selling an ignition module for a R32 GTST / GTR send me a PM with a price ;)
Edited by Dave69001
hey!...this was a great read!!! Really appreciated the post!!
Goodonya Dave!!!!!
What have you been driving in the meantime, while all this nerve racking shite was going on?
Ive been riding in style on the bus for the last 4 months because I lost my licence for 6 months :) (Still got 2 months 9 days to go)
thing that pisses me off so much is that if I didnt lose my licence the battery wouldnt of went flat from the car sitting their so long so I wouldnt of taken it out then connected it again the wrong way.
Ah well lesson has definately been learnt.
this is an ausome lil story, i just found it off the link in dantays sig and my eyes were glued to the screen, im soo glad everything worked out david.nice to hear a story with a happy ending, even if it was a nightmare situation. well done.
btw ;) for putting the leads on wrong in the first place lol just joking
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
