Friday Nite Coffee + Sat 21st /22nd Sep 07
Hi Guys i know its short notice.. but here it is anyway.. kept getting asked if there was one this week well yes there is .. there is however a change in location as the usual spot is going to be closing down around 5.30pm from 1st october so we are going scouting for a new place
Time : - 6-7pm (Anytime In Between)
Date : - 21st Fri , 22nd Sat
Location - As USUAL coffe club near coles
Most of us will be taking a short walk stroll towards mt gravatt showgrounds to check out this curry thing thats on .. FOOD !!!!
Wack away if your keen to attend.. New commers are encouraged :D we dont bite .. that hard lol
Please put your name below and i will update the list and state weather fri or sat suits you
Havent decided yet what we will be doing later on seems like a Cruise to West End if anyone is keen for both nites and a short drive towards Northside (Location withheald) of course this is for a pic shoot :P
Things to bring...
- Clean Car !...
-Jumper
-Some Loose change for toll etc..
If anyone new wants to join or is unsure of how to get to the location PM me or add me to msn
cheers
Vish
Attendees - FRI Nite
-Devils_Advocate
-53XYN
-Choyda
-Pink32
-MissNiz
-BlackNinja
SAT NITE
-53XYN
-MarkiMark
-Devils_Advocate
-Pink32
-Long33
-Col-GTSX +1
Edited by 53XYN
ill head up on sat nite vish missed u all last weekend but i had to get that damn fm onto the car. we just meeting at the usual spot or have u already found a new coffee joint??? lemmie know chio brothas
I'll be there Friday night.
I'm dying to see Damo's new ride, so i'll most probably be in for friday night! Although i might be in the new daily driver... :thumbsup:
Edited by Miss Niz
Hey guys im out on a shoot with another photographer on Saturday night in the CBD for a work thing and should be finshed by 7pm, interested?
I could swing by with him and take a few shots with you guys! Oh and have a latte of course...
Cant bring the skyline tho as I need the sapce to carry the equiptment so the SS will have to do... :wave:
Sounds like fun guys Cruise and pic shoot will be Sat nite as with the locations described , however i will be posting up pics of everyone who attends tonite
If thats your GTR in your signature Damien then im gonna hump your leg...
Thats soooooooo soooooooo hot!!!!!!!!!
So Vish, im confirming yes for Saturday night, me and a collegue will be there for 7pm and will enjoy a few coffee's and will just go with the flow.
Out shoot finishs at about 6 - 6:30 aparentlly, so we will be ontime (round 6:30-7pm)...
Sat is a bludge day, so I'll wash the car and come out for a cruise finally.
would be nice to see u again, i think u were the guy i met at bp yatla on the way back from the cootha cruise
and we cruised to the spit to meet everyone?
Location - Mt Gravatt
Shop 32, Mt Gravatt Village Shopping Centre
1932 Logan Road
Upper Mt Gravatt Q 4122
is this the coffee shop we usually meet at? u no i dnt no brissy vish lol
hey col yeah we are up for it :P sounds good :thumbsup: great idea heh ..
Darren , no it isnt at the same shop its further up towards city about 3km more from the usual spot i will post a map for you guys tomm morning
opps
this is my bros account lol
Cheers
Vish
P.S Col u wanna hump Choys leg.. humm i think i will beat u to it tonite :D
Edited by GTR_83
Don't think so, haven't been out cruising in a while, but will try to get there tonight.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
