Very specifically I require;
A speedometer and speed sensor from a 1989 model R32 GTR. A 1990 model may be sufficient also but the speed sensor must be of the 3 screw sensor!
If unsure what the speed sensor is...
When you open the cluster up (a few small clips that simply pull open, but can be pushed back shut), when you undo the speedometer the speed sensor can be found on the back of the speedo unit, pictures are;
http://www.skylinesaustralia.com/forums/index.php?showtopic=152998
HERE
Anyway PM or email (best) [email protected]
Edited by Keeper
https://www.sau.com.au/forums/topic/185774-r32-gtr-speedometer-1989-model/
I've got what you need. Speedo cable and speedo instrument out of early gtr. (my cars donor parts).
$220.
PM if you still need.
If you live in Bne you pick and choose the exact one you require. as i have a few.
Cheers
  • 1 year later...
I HAVE A CLUSTER IN BRISBANE $175
can you confirm it is a 3 screw sensor unit by taking a photo of the back of the odometer assembly under the rear cover please? i have purchased a couple units now and neither have been as advertised
quik question since you seem to know a bit about this
i have been told you can tell what type it is by the color of the wiring/schematics on the back of the cluster ??
cheers
dont think so, you can get that rear cover off with about 2 mins labour tho
I SEE WHAT U MEAN MATE.. SORRY ALL MY ARE 2 SCREW
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
