Pics of rear wing please..
Any idea if the diff is 2 way or 1.5 way? how long has it been on the car? any clunking or whining?
Cheers
Johno
DIFF IS 1.5WAY AND HAS BEEN IN THE CAR FOR ABOUR 8000KMS AND NO PROBLEM WITH ANY OF THE ITEMS IM SELLING HERE....
https://www.sau.com.au/forums/topic/185822-sold-sold-sold/#findComment-3361605
