I can lend a hand if you need. I *might* be able to organise hoist time for a reasonable rate if you need.
Although there is the obligatory requirement of a slab :(
Its not a 5min job... a hoist helps... if you dont then a trolley jack is a MUST otherwise its a no-go.
What are you gonna use the hoist for? Lifting out the turbos? I didn't realise they were so heavy
Seriously though, pull out your spanners, screw drivers, sockets and just start pulling things off. Pulling things apart is easy! just remember how it goes back together again.
Hoist - to lower/raise the car maybe? :sorcerer:
More to point, its not a job you can 'just' do from the over the top of the engine bay.
You need to get under the car more than once as dumps have to come out, turbos have to be dropped in a certain order etc etc.
Not everything is accessible i believe from over the top. Youm must go underside on a few occasions.
So on a trolley jack/stands... going up/down a few times is a pain the the a$$. It can be done, but a hoist makes life a lot easier and faster.
You need one of these ^
Then point at said turbos and say:
Concealment Charm
Which means:
Used to conceal something so that it cannot be seen.
lol, where does one find one of these fancy things...???
ash is on the money, pm me if u want some tips as ive had to do this exercise once or twice. :(
Edited by barney
A digi cam is your best mate, take LOTS of photo's then go through them backwards when putting it together again, works a treat :(
yeah started takin it all off but when nothings been modified before its hard cause its all seized i'm a mechanic but neva come to the point of so many seized things aaaaaaaaahhhhhh :(
yeah started takin it all off but when nothings been modified before its hard cause its all seized i'm a mechanic but neva come to the point of so many seized things aaaaaaaaahhhhhh ;)
Good to see you took the wand option! :(
Wands are best purchased through Hagrid's Wholesale, best value in town :)
Just give is a squirt of WD40 or similar 1-2hrs before you start.
What exactly is "seized" as such?
With leverage, nothing is too hard to remove, just need to think of different ways to approach it sometimes... that was my biggest challenge with my low-mount/ext gate setup. The obvious way wasnt the easiest/best ;)
yeah manifolds to head dump pipes to front pipes plus this is my first time i've pulled a gtr apart so dont really wana brake anything cause its costs alot to repair almost at point of droppin it off at racepace an let them deal with it!!!!!!!
Bahha. subtle! translation: 'by using the tools in your toolchest, combined with your knowlege as a mechanic you should be able to get the bolts of. Difficulty is of a low level. you should not have a problem.'
out of curiosity, why are you taking them off? upgrade? gasket? just checking?
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
