Hey Guys,
Im Selling my 90 32 GTR as is, cause im moving interstate and cannot afford to repair and take with
Gun metal
Lots of A/M parts on car and seperate
A/M Turbos
Turbosmart FPR
Mines CPU + Standard
Standard wheels available
catch can
e.t.c
**** This Car Requires Rebuild as Big End Bearing Gone ****
The car already has a new water and oil pump on it both with less than 5000kms on it i have reciepts for these
There has been a brand new exedy 6 puk button clutch installed which has less that 1000kms on it its not even bedded in yet.
All diff and gearbox fluids have been changed to Motul and shockproof products.
Any enquiries please feel free to PM me or give me a call on 0437198329
Car will be sold without 18x9.5's or with at the right price.
PRICE $14000ono Looking for a quick cash sale all offer will be Seriously considered
Cheers
JUST THOUGHT I WOULD MAKE POTENTIAL BUYERS AWARE OF THIS
CRD is offering members unbeatable deals on engine components for RB26 rebuilds
ARIAS Pistons
EAGLE connecting rods
NISSAN (Genuine) gasket kit
TRUST drag metal head gasket
TRUST camshafts
ACL race series engine bearings
Total price only $3599.00
Parts can be purchased on there own if required at the best prices.
Purchase from CRD and save on expert installation and Dyno tuning.
CRD can also be called at any time for assistance.
CRD have been trading since 1989 and have over 70 years combined experience!!
Croydon Racing Developments
CRD
[email protected]
9 Blaxland st Silverwater Ph 96484264
https://www.sau.com.au/forums/topic/185849-fs-1990-32-gtr-cheap/
Yup everything else is spot on, all new fluids, gearbox is spot on and has a brand new exedy 6 puk button clutch which hasn't even been fully bedded in yet less than 300kms since installation.Car has new genuine nissan water and oil pump done at 100xxxkms with majour service. Car body is straight as, as you can tell from pics,
As Stated before Obviously does not include labour but there is all your parts for a serious RB26,
And your local machine shop should be able to do all the machine work and peice her together for $2k
(what i was quoted )
ARIAS Pistons
TRUST camshafts
CRD
[email protected]
I am looking for a very quick sale if possible
Thanks
Hey guys sorry i dont have access to a cam at the moment however i have now reserved my tickets now and this car has to be sold and i mean sold, i will be taking all offers very very seriously
Thanks for all the intrest
Rob
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
