Hi all,
I have an internally gated 1.06 exhaust housing from a 700hp GT35R that I purchased from GCG at the start of last year (with receipt) for sale. I checked with GCG and they sell these for $880 (Just the exhaust housing).
I had a 6 month license suspension across this time so it has barely seen 5,000km since install. Absolute new condition.
$400
Reason for sale is I am going a smaller housing due to staying with standard engine.
Please PM me or call 0400648813
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
