TJ!
Have a look at the CAMS website and then look in "calender"and search for
"event - all"
disipline - all or kahna etc
select dates and then multi-club and it will tell whats coming up - although not much coming up at the moment
With the 2007 motokhana round - held on sundays (dam work) by car clubs like "thornliegh car club/ hills c/c Mg owners c/c etc etc
they have rounds thorugh out the year and its around the $50.00 mark for entry and you compete!
other than that theres not much else unless you search other car forums and find out if they hae a skid pan day etc
p.s. I owe you $$ for texi accomo
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3364188
The cams khanas are good, Neil has done heaps and a few of us did a couple of rounds a few years back.
Only thing to keep in mind is the offical courses are very tight compared to dutton or the deca copies.
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3365937
Are Skylines competitive? I'd been keen to give it a very serious effort as team SAU NSW. I can see where you can get much better with experience.
Hi - my names TJ and I'm a khana addict....... its been a week since my last khana....... :)
Would you like to join my support group?
On another note, I just got the car to the carwash this morning. I'm definately over the wet skidpad thing.
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3366863
not competitive overall - outright is won by motorkhana specials, basically a little larger than a go kart with auto trans and 2 brake pedals (front and rear) running on slicks. they are amazing to watch.
classes are broken down by car length A/B/C/D and specials. Skylines are well and truely in class D and can win it for sure.
So, it is brilliant fun, very technical, good driving skills practice and class based so you can compete against similar cars.....great fun, and all for $40 for a day's racing
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3367079
lets get to a few rounds next year then for team SAU NSW? :D
IN! Except for high rpm launches.......f**king triple plate clutch :P
Hi - my names TJ and I'm a khana addict....... its been a week since my last khana....... :P
Thats funny cause its true
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3367225
I'll be in it, Just gotto join the club.
I used to compete in a BMW 318is and would easily win my class (Class D, mainly Falcodores, other BMW's. would include skylines but I never saw one)
Now I have my 32 I want to start competing again, just gotta get a couple of things first, 1.5way and maybe even a Hydro handbrake
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3368520
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
