TJ!
Have a look at the CAMS website and then look in "calender"and search for
"event - all"
disipline - all or kahna etc
select dates and then multi-club and it will tell whats coming up - although not much coming up at the moment
With the 2007 motokhana round - held on sundays (dam work) by car clubs like "thornliegh car club/ hills c/c Mg owners c/c etc etc
they have rounds thorugh out the year and its around the $50.00 mark for entry and you compete!
other than that theres not much else unless you search other car forums and find out if they hae a skid pan day etc
p.s. I owe you $$ for texi accomo
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3364188
The cams khanas are good, Neil has done heaps and a few of us did a couple of rounds a few years back.
Only thing to keep in mind is the offical courses are very tight compared to dutton or the deca copies.
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3365937
Are Skylines competitive? I'd been keen to give it a very serious effort as team SAU NSW. I can see where you can get much better with experience.
Hi - my names TJ and I'm a khana addict....... its been a week since my last khana....... :)
Would you like to join my support group?
On another note, I just got the car to the carwash this morning. I'm definately over the wet skidpad thing.
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3366863
not competitive overall - outright is won by motorkhana specials, basically a little larger than a go kart with auto trans and 2 brake pedals (front and rear) running on slicks. they are amazing to watch.
classes are broken down by car length A/B/C/D and specials. Skylines are well and truely in class D and can win it for sure.
So, it is brilliant fun, very technical, good driving skills practice and class based so you can compete against similar cars.....great fun, and all for $40 for a day's racing
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3367079
lets get to a few rounds next year then for team SAU NSW? :D
IN! Except for high rpm launches.......f**king triple plate clutch :P
Hi - my names TJ and I'm a khana addict....... its been a week since my last khana....... :P
Thats funny cause its true
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3367225
I'll be in it, Just gotto join the club.
I used to compete in a BMW 318is and would easily win my class (Class D, mainly Falcodores, other BMW's. would include skylines but I never saw one)
Now I have my 32 I want to start competing again, just gotta get a couple of things first, 1.5way and maybe even a Hydro handbrake
https://www.sau.com.au/forums/topic/185988-motorkahanas/#findComment-3368520
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
