yep now where getting somewhere
some of lambos questions answered
Does those BOV that vent excess air when the throttle is shut affect the air fuel ratio?
Yes because the ecu has accounted for that air as being already in the engine
Since the throttle is shut the air getting into the engine should be the same even without the BOV.
No because the would get in when the throttle is re opened and the throttle is never completely closed the motor needs air to burn the fuel
Isn't the job of the BOV is to pretect the intake turbine from blow back pressure from shutting the throttle abruptly.
Yes and to protect the turbo from spinning backwards in the case of a backfire
Can we fix the Bov so that it comes before the AFM?
Is it even possible?
No the ecu would read the air eneering the engine twice causing a very over rich state
I do not understand how the return BOV works. If it return the excess air back into the intake doesn't it defeat the purpose of having a bov to relief the back pressure from sudden shut of the throttle?
It simply removes the pressure between the throttle butterfly and the turbo outlet on the compressor side of the turbo by putting that pressure on the inlet side between the turbo and the afm
Anyone knows about those return BOV that vent gas back? and the above post also
lambo I’m not quite sure what you mean by this question
Lambo short of replacing the ecu the only fix for the problem is by adjusting the air bypass valve at the back of the inlet as I stated in my post on the first page.
  • Replies 44
Originally posted by greygirl1976
yep i hate afm they sux i just need a aftermarkrt computer so i can do low 12s car shuts down{limp mode} at half track on 8-10psi
AFM sux? So, you get your fuel for free then? I like AFM's. If you need more power than the one you're using can handle, just get a bigger/better one with more resolution. MAP will almost always use more fuel than AFM with everything else equal.
yeah.... AFM's are the most accurate way of measuring, so youdo get better fuel economy, and there are some cars with good horse power still using AFM's.... I have MAP, and it's not bad, a bit rougher than the AFM, but it's all good :rolleyes:
  • 1 month later...
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
