Need Rb25 Injectors And Fuel Rail Urgently
Update from today; Hard work was completed today behind a computer... Ha ha Hardlines for new fuel lines ordered, and fittings for it to connect up too. Banjo fittings for owner steer ordered too, will be AN fittings. Ordered all the weld on fittings I need to build the PS reservoir too. Only things I'll need left for power steer is a couple of off the shelf fittings for the pump, and to build 3 lines.
That's a DB1521 (Benshit reference code). -
Rears are DB1521 or IN1521 in Intima. DB1220 are for non Brembo. -
By PotatoCake · Posted
Im not sure of it looks on your setup, but i cant see the exact pad style without taking everything apart -
I'm not trying to be rude - but can't you just go and take a peek at the pads you already have. I mean - they're right there, visible between the spokes of the wheels.
