Hi all,
had a lapse in concentration the other night and didnt take a steep driveway at an angle and below is the result. :)
Does anyknow know if this will be fixable DIY? I havent done any fibreglassing before, but am willing to give it a shot! if people think its worth while i'll give it a go, or am I up for a new bar?
Thanks!
Some pics of the damage
Anyone know if this can be fixed?
https://www.sau.com.au/forums/topic/186008-who-has-done-diy-fiberglass-repair/
not a hard repair, just fibreglass the rear of the bar first for strength, allow to dry, then fibreglass the bottom lip and roll it around the front to cover the damage. ensure the rear of the crack is covered completly, this will stop the bar moving.
also ensure you use some sand paper on the back of the bar to make sure the glass sticks to it good.
to finish it off use some bog which u can get from any paint shop and fill any small defects with it, sand the lot for smoothness on the front and send it off to get painted.
if u have any questions, pm me, i work with fibreglass all day everyday, so i know what im talking about.
cheers
daniel
Thanks for the help cheez!
Any tips for how/where the bar should be when doing the repair and drying? Im worried about glassing it up to find the bar is twisted or something and won't sit back on properly
when doing it take it off the car grind it all back the section where its cracked both back and front gring atleast a layer of fibreglass so you can remake that back when repairing it. also do it when its a hot day so it will adhere fast need bog and all that shit aswell
well said mate, definitly have it off the car, put it over some trestles and use it like that. if u cant wait, do the repair in an enclosed area with a resiprator on and a heater to increase air temp, or wait a few weeks til end of oct when weather is better.
make sure u scuff the back of the bar and a light sand on the front to remove a layer around the damage.
my advice would also be to get more glass and put a thick layer all along the back of bar along the bottom to reinforce it. i did that with mine (i had to patch it up anyway since i bought it second hand and it had been broken in 2 just below the passenger side headlight). we just added a heap of glass onto the back of it to strengthen it up. and i hit some fury animal at about 70kmh pulling off the highway 1 afternoon right in the centre bit below the number plate and only ended up with 2 cracks about an inch long.
you need the glass as well as the resin/hardener. it is a messy job.
all you do is (this is a very basic run down) sit it in the position you want it to be in when it is done, mix up the resin (make it a bit stronger than they suggest, that way it will set faster and a bit harder), lay on some of the glass, and put some resin on using a paint brush and spread around, then add more on. make sure you do it in layers. do the full area with 1 layer before you start the next.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
