hey there... hope someone can shed light on this problem...
had a bit of a race the other night and after i backed off the car just all of a sudden lost power and spluttered under boost... it had done this on a couple of occasions before this but all i did was turn the car off and back on and the problem went away...
it also is hard to start (mainly when cold) eg. it just kicks over and wont start then pops back through the inlet then eventually runs ok-ish
it runs ok until it gets to 3-5 psi then splutters and misses and is under power...
my turbo is shagged so its blowing oil into the inlet and the factory bov was putting oil spray on the AFM so i tried cleaning it with degreaser then metholated spirits, after this it didnt seem to change anything
i then thought coil packs leading to waek spark so i checked over them found 2 that looked like they might need replacing, plugs are less than 6 months old but pulled them out to see if they had carboned up... and they look slightly black but still in good condition
its kind of like its leaning out under boost maybe but no pinging, no raised engine temp, and plugs dont look burnt,
no oil in water, no water in oil, not losing water so doubt its head gasket
i just cant work out what it might be... asked a couple of mates and they have no idea either...
could it be the AFM on the way out and messing up the fuel mix
any ideas or info would be much appreciated :)
https://www.sau.com.au/forums/topic/186009-rb20det-losing-power-under-boost/
havent checked that yet... can that just happen and it be fine to drive under boost?
spoke to a mate with a rb like mine in his silvia and he said i'm having fuel pressure issues and it might be pump or filter as what i discribed was what his did so i'm gonna have a look at my filter and pumps now and see if anything comes up
Check the fuel filter.
Plugs may look fine but maybe the gaps are out.
Maybe bad batch of fuel?
Also have a look/check your intercooler piping incase something has popped off.
Don't think it would splatter if it was running lean. By the sounds of it it seems as if its over fueling.
Hope that helps some how.
not the fuel... same tank as when it was running well...
how could the gaps change from when i gapped them when i put them in?
checked the filter just then... now i just have a strait bit of pipe where it was
just checked the pumps... tried reversing them to blow out anything stuck in them... managed to kill my low pressure but thats no biggie as i have 2 spares....
if its a fuel thing i'd have to say the high pressure pump isn't pumping good pressure making it hard to start and bad when on boost... but its a bit of money to spend on just a hunch
not meaning to shoot anyones ideas down... i'm just trying them as i go and writing them out
thanks for the help everyone
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
