R34 Rb25det Neo Vs. R33 Series 2 Rb25det
pricer-1
 Share
So I have been looking into a RB swap for my S13 and I think I want to go with the R34 Neo but I have a few questions about differences between the Neo and Series 2 engines. When it comes to upgrades or even just OEM parts will the parts for a Series 2 motor work on a Neo? Physically what are the differences? Also what parts should I consider replacing before installing the engine into my S13?
Theres plenty of neo specific head upgrades like poncams and fine tune timing belts ect. the stock rb25 neo has superior torque and power to the earlier rb25 also.
Parts to replace. Might want to look at a set of splitfires, i had problems with standard coilpacks failing. Other than that i cant think of anything, unless u want to go for extra power. :nyaanyaa:
Edited by silverr34gtt
Parts to replace. Might want to look at a set of splitfires, i had problems with standard coilpacks failing. Other than that i cant think of anything, unless u want to go for extra power. :thumbsup:
I have seen a lot of people talking about replacing the water pumps, oil pumps, time belt, timing belt tensioner and idler pulley, etc bc the engine is most likely coming from a junkyard and has been sitting for a while. Do you think it is all necessary precautions?
Water pump, timing belt + idlers, crank + cam seals, various water hoses. From the viewpoint of ensuring absolute reliability in those areas - YES. Oil pump as a service issue though, I doubt it.
Some of the parts aren't particularly cheap, but if you consider the time + labour factor involved once an engine is in the car, it is a smart option while the engine is sitting on the bench/workshop floor.
Honestlly the Neo motor is going to be younger, so it would be the better option...
However that said some second hand Neo's can be rather expensive compaired to theolder S2 rb25, so I guess you just need to weight it up...
But on the solid lifters alone id be buying a neo motor...
it somes with hks fuel rail bigger injectors, fuel reg and better coil packs. i have a good turbo so prob just a computer and i guess i would be happy for a while. but just wanna no. some people say s2 25 is the best and some say neo. just real confusing. dont wanna get the wrong one hahah
Another issue to consider is what ecu you plan to use.
For example: At this stage in time, the Wolf V500 is not yet fully compatible with the NEO, but i know they'll be fixing that soon.
Go for the better, newer Neo if you can afford it.
S2 RB is great engine too, and will be cheaper to buy and probably cheaper to mod (if thats the plan), but it's not as advanced as the R34 Neo.
The Neo is more enviromentally friendly. Guess that's not important on this forum :thumbsup:
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
