  • Replies 409
Posted Images
yeh mate i do unfortunately.U know the car do ya
Yeah i used to drive past it like 5 times a day but then my office moved and i dont go past there as much anymore - maybe once a day now
I really like your wheels :D
Thanks mate.Do u drive ur skyline past everyday or do u have a daily that u use for work.Do u think my car is worthy of sau autosalon thing
I have 2 daily's - one holden berlina and one supra twin turbo, i drive the supra most days :D
f**k yes yours is good enough
I'll enter on one condition.
Jess has to say "liz, your car is so much sexier than mine"
and have it in her sig for a week.
I'll enter my car on the following conditions :
* Jess changes her sig to "13B's Are POWERHOUSES"
* Jess changes her phone ring tone too "RX7's Superior, Skylines Inferior" in my voice
* Liz & Jess both wear "Mazdaspeed" tops at AutoSalon
interested in having an rb25dett? i would like to come along but it is nowhere near a show car. basically a track car with numberplates but with some good gear on it..
dont know what you guys are after but mine is something different haha
I drive past you everyday too.
Do you also have a 31?
are you the chick the scoots past in a white 33 gtst.I would say more of a wanna be 31 its a nugget pintara thats just like a daily.Heap of crap but a good car
I have 2 daily's - one holden berlina and one supra twin turbo, i drive the supra most days :whoops:
is ur supra white i see a white supra go past all the time.Habing a Twin turbo supra for a daily must mean u have a good job.Im only a shit kicker mechanic
OMG LOL!!!
sif this would ever happen...
but it is a deal!!
Definately if your up for entering...We would love to have your car :(
Is this the one brad is building??
Please fill out a form and bring it to the meeting if you can make it...Please tick the box if you want to put it on the dyno :whoops:
Nah, not white, its black, if you see it come say hi
Yeah i have a good job, who do you work for - is it Ford?
Heres a pic of the supra
http://www.skylinesaustralia.com/forums/in...t&p=2980521
Well... it's been a while for me. Doof and Jess you know my car, except now it has a lot more under the hood, some light interior work and added gauges and a carbon fibre stealth wing :) Basically it's jap spec in the looks department. If you want it for the autosalon I'm up for it but it does currently have a few small key marks from some c#&t on the rear left quarter panel.
i cant even find when the next one is on lol.
yes brad is piecing it together, it's essentially the kit jago on the forums had but different pipe setup. and if he gets back to me in time maybe some 2530s, but so far it will be r33 turbos.
I'll check it out on thursday when you pick me up for the meet :bunny:
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
