pft, no one lives at Newtown :)
Jks! Yeah I dunno... Ask some newtown people I suppose...
Maybe send a message to [uLOOOK] (i think) on the forums... or Guilt Toy, he lives up that way now too ;)
(For the record, I'm actually talking about Newcastle)
  • Replies 409
Posted Images
It's not that strict... We were moving cars in all through the night last time, they know what it is damn near impossible for 12 people to all be there at the same time...
But yes, I was going to post that email... I suppose anyone who supplied an email got one?
Rar :)
We have to set up first anyway... I didn't write a move in time, so I don't know where they got that, but the are won't be ready by 4...
But then again, we can move some cars in and work around them if need be... It really isn't that big of an issue...
just received an email from autosalon notifying me that the "move time" is 4pm tomorrow. is this the case for all us in the skyline group? or ppl have different move in time?
Yeah they just do that as a rough time..It never goes to plan tho... Pretty sure we had the cars in the pavilion while we were setting up, cause usually a big line up all night :rofl: When ever you get there just try and move in where our display area is....
I am bring the flooring around 7pm as we are all to busy to get the flooring there any earlier :rofl:
hey guys i will be there on sunday as a spectator so see you guys there and it will be nice to meet you guys my name is Dale by the way.....
Awesome see you then!!!
Just turn up whenever. They will still let you in late at night even. I got in last final battle at 10pm.
I am demoted to CO :(
Anyways, I just got back from setting up the show... i was so busy I TOTALLY forgot to take ANY pictures...
My legs, feet, back, brain and bank balance hurts...
I was talking about his friend!! I didnt catch his name and that was at lunch time that I made that post when he came to pick up the not needed flooring :huh:
Shame about so many people pulling out last minute..
Would really like to see the entrants get more involved when its there cars they are displaying!!
Jay and the company he works for have been really great with the very generous expensive lighting and plasma's!!! Thanks heaps Jay really appreciated it :):)
Thanks to all that entered and Doof for all his organising :)
hey SAU'ers...tomm. the "twoogle" is going for the world power record for a low mount GTR. Good run today with the rich tune, made 650hp/485kw...will make over 500kw tomm. and set a new benchmark. But..tonight we must party!!
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
