  • Replies 409
Posted Images
yeh mate i do unfortunately.U know the car do ya
Yeah i used to drive past it like 5 times a day but then my office moved and i dont go past there as much anymore - maybe once a day now
I really like your wheels :D
Thanks mate.Do u drive ur skyline past everyday or do u have a daily that u use for work.Do u think my car is worthy of sau autosalon thing
I have 2 daily's - one holden berlina and one supra twin turbo, i drive the supra most days :D
f**k yes yours is good enough
I'll enter on one condition.
Jess has to say "liz, your car is so much sexier than mine"
and have it in her sig for a week.
I'll enter my car on the following conditions :
* Jess changes her sig to "13B's Are POWERHOUSES"
* Jess changes her phone ring tone too "RX7's Superior, Skylines Inferior" in my voice
* Liz & Jess both wear "Mazdaspeed" tops at AutoSalon
interested in having an rb25dett? i would like to come along but it is nowhere near a show car. basically a track car with numberplates but with some good gear on it..
dont know what you guys are after but mine is something different haha
I drive past you everyday too.
Do you also have a 31?
are you the chick the scoots past in a white 33 gtst.I would say more of a wanna be 31 its a nugget pintara thats just like a daily.Heap of crap but a good car
I have 2 daily's - one holden berlina and one supra twin turbo, i drive the supra most days :whoops:
is ur supra white i see a white supra go past all the time.Habing a Twin turbo supra for a daily must mean u have a good job.Im only a shit kicker mechanic
OMG LOL!!!
sif this would ever happen...
but it is a deal!!
Definately if your up for entering...We would love to have your car :(
Is this the one brad is building??
Please fill out a form and bring it to the meeting if you can make it...Please tick the box if you want to put it on the dyno :whoops:
Nah, not white, its black, if you see it come say hi
Yeah i have a good job, who do you work for - is it Ford?
Heres a pic of the supra
http://www.skylinesaustralia.com/forums/in...t&p=2980521
Well... it's been a while for me. Doof and Jess you know my car, except now it has a lot more under the hood, some light interior work and added gauges and a carbon fibre stealth wing :) Basically it's jap spec in the looks department. If you want it for the autosalon I'm up for it but it does currently have a few small key marks from some c#&t on the rear left quarter panel.
i cant even find when the next one is on lol.
yes brad is piecing it together, it's essentially the kit jago on the forums had but different pipe setup. and if he gets back to me in time maybe some 2530s, but so far it will be r33 turbos.
I'll check it out on thursday when you pick me up for the meet :bunny:
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
