Hey all,
hoping for some input: I just rebuilt my engine have had the oil pump die and drag my crank to hell with it... so new crank, bearings rings pump and so on...
No I am running the engine in at the moment and on the home stretch, but the car feels like it lacks power compared to what it used to... I drove my house mates supra the other day which has nothing on my GTR and I swear its running faster than mine :nyaanyaa:(
It's still on "running in" fluid, I have a Greddy boost gage and a HKS EVC which reads the boost also... and of course the stock gauge which means nothing to anyone... the Greddy gauge isn't reading properly, its just bouncing around and not actually doing anything even close to measuring vac/boost thats just because I havent connected the electrics back up for that properly I assume.
The HKS EVC is messuring me at 6 pounds which is what I always ran but the car just feels a little lack luster.
By rights I would have though... considering the head was shimmed before putting it back on and the rings have been replaced, my compresion should be a little even if not measurably higher.
So the engine is back together to every spec and torque...
Any ideas?
pretty sure stock is 7pound is standard. im sure i read it somewhere and thats what the standard gauge reads up to.
maybe your workshop set it on 6pound to make sure you take it easy on the car while it runs in.
Hey all, thanks for the help so far, but it only ever sat on 6 psi, and was plenty fast, sometimes when I was feeling adventurous I would lift it up past 10 psi but not really very often.
Any other thoughts?
I will look into that though thanks :D)
stock boost is not 10psi.
for those who think it is, go and redo your maths. the guage is mmHG not psi.
Stock boost sits around 7psi.
your problem could lie in electrical. maybe an AFM, its hard with cars like these, problems lie everywhere. good luck
Yeah i agree stock boost is 7 Psi i had mine on the dyno and with stock exhaust everything stock it didnt produce more than 7Psi we took the restrictor out and even then would raise more the stock exhaust was out of flow efficiency car wanted to boost but couldnt get the gas out .
Even the standard boost gauge goes to 7psi also, i have witnessed everything that i have talked about have a good friend with a dyno and we played with the R32 that night to see how it ran stock, let me tell you also they run very pig rich in fuel side of things good to know as the ecu will accomodate a boost increase with A/F ratios that Nissan gave the Gtr.
Cheers,
Dave.
ok then, now I have not walked out to teh car to check, but suppose the EVC is reading in mmhg as well... that would mean I am still on the right boost and getting no power at all.
Can the cam angle sensor being slightly off cause this problem? I marked everything for replacing and its all in the same spot but still shit happens...
I really appreciate your help so far all.
This is the new HKS EVC? I know that one is kPA(bar) or PSI selectable.
Therefore your running 8.7psi(0.6bar) or 6psi. well under stock.
Strange indeed.
Boost - #1, id check the EBC for what unit of measurement its using. Hook up your lecky gauge properally, or use a known good mech unit from a mate, run some dodgey hose out the bonnet, through the window; good to go in 30seconds.
Power - was it built for same compression? same headgasket etc? Are you noticing lack of go when under load, or does it seem to free rev tightly? Talk to your engine builder about bearing clearances. You prolly at this point check ignition, do a quick comp test (Just for shits n giggles, results could be hard to compare depending on KM's of run in)
As for boost, the manual might say 11.5psi, but iv def seen 8 on more then one car. When mine hit the shores of this dry country, it'd run 10.something psi, with pods and a cat back so who knows.
Hand the thing back to the tuner when run in, crank a few bar into it, then complain about the 20kw loss... :P
.. oh and wax that 2JZ
EDIT: Pretty sure most ppl see 1bar with restrictor gone SeeyaGTR
EDIT2:
Could you have ran 6 pounds, which is lower then the factory gate pressure? :P Me thinks you'd have to have your units of measurement mixed up. :D
Edited by GeeTR
yes it reads in mmg or what ever, just had a look...
now heres teh thing, it revs up perfectly, you cannot fault the car for how smooth it is running, but I just got smashed by a v6 magna...
so the pressure is reading at 0.6 mmg which it always did, and the car just has no go.
you can feel the boost but it doesnt kick you in the arse like it did before build.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
