Hey all as promised Next months HPI has the shownshine artical with pics so dont miss out, It should come with the DVD with the event on it also.
Thanks to all the people who helped get the pics for the artical too. :thumbsup:
I have not seen it yet :P
https://www.sau.com.au/forums/topic/186061-next-months-hpi-issue/
  • Replies 69
Yep, it's in the new release of HPI. The article was written (and very well, too) by our own Andrew "nuttsHunglow" and features photos from the HPI crew, as well as E_Lu_Shun and a few others.
Good article, if a little short considering how big the day was for SAU-NSW - it was our biggest Show and Shine to date, and probably would have been bigger if it wasn't for cold and the delays due to the wet weather leading up to the original date.
I have not read it yets sorry and I hope all who sent in a pic towrds the artical got a mention.
rememeber there is the Ignition DVD too so if you where alking around on the day you might be on it. I know abo bob is i ran where they wanted to interview for the day grabed him and mad him do it lol
it should be out by thursday at the latest VIC!
I read it last night at Nicks place and let me say I liked it 7 pagers with a few members to be seen in it also some people where mentioned Not going to say who so you will have to get a copy I liked it i thought it was good for the club and also the sponsors.
Oh me too... I parked next to drift spec :P
lol, woooo!!!!! thats ME!!! except i'm not really drift spec anymores... you can call me.... babyzilla...
however, i shouldn't say this, but i took my back seat out two weeks ago and still haven't put it back in... :whistling:
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
