Ash, that's exactly why we are 50/50 on the porting.
If the restriction is in the turbo housing itself, then opening up the exhaust manifold isn't going to make much difference, however if I was running a monster turbo, then the more flow I can get through the standard exhaust manifold, they better.
or, you guys could all continue to wait until i finally swap over my extrude honed manifold and get some results, unfortunately dont hold your breath tho :)
Wow, im pretty damn sure i didnt pay 600 bucks!
One thing i remember him saying was the smoother flow resulting in less heat. ie, before where a manifold would glow red hot after some hard dyno runs, it wouldnt do so once ported. So possibly benefit there too.
Cubes, i think i remember that thread you refer to, and if i remember correctly, it was the 'extrude honed' standard mani that flowed some figures similar to some of the aftermarket ones, not the untouched version. ?
edit, actually cubes your sort of right, i just checked, the HKS cast mani was shown to flow just 10cfm more than the stock untouched mani, meaning the ex honed std mani would far better the stock HKS in terms of just 'flow'.
Setup is as in sig, not with stock turbo
Edited by SLY33
I talked to a Extrusion Honer just recently, and he said to me that you have to watch out for the people that don't do the honing correctly.
He says the best way to do it was to Block off 5 runners, and do each runner at a time, because a lot of people try and cut corners to increase speed and do all 6 at once. If you do all 6 at once then the easiest flowing runner is going to recieve the bulk of the abrasive fluid that hones these manifolds out.
He said he charged $550 for a Sinle RB25 manifold.
I too was a bit disappointed at the price, but when you compare it to a HKS item, for $100 more, you could easily have a External Gate provision fitted.
Pros:
1. Looks dead stock
2. Flows more than the HKS Item
3. Half the Price of a HKS item \ Stainless job from the expert fabricators here
4. A lot stronger than the Stainless items
5. Heat stays inside cast better than stainless (meaning more pressure through your turbine, increasing response)
6. Bolts straight back into factory position
Cons:
1. Not Shiny
2. Maybe not tuned length? (does this matter?)
3. Still a bit pricey
4. Only a low mount option
5. Need to find someone that will do it properly
And no split external waste gate mount .
You're going to find that its the pressure drop over each manifold runner thats important not its constant flow rate . Piston engines don't have a constant gas flow rate on either side because the valves are opening and closing . However if the cylinders feel a consistant pressure drop through the exhaust manifold it tends to equalise their flow velocity and thats what the engine and turbo prefer .
What the HKS manifold also does is angle the compressor end of the turbo away from the block so packaging is a bit easier . Also if you drill/tap the four extra holes you can use a T4 flanged single/twin entry turbine housing . The RB26 version suits only the T4 flange size .
Cheers A .
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
