the studs and nuts that hold the turbo's on are good to change. once they've been on for a while and you loosen them of they just don't have the same holding torque anymore. don't really want them rattling loose. lines would all depend on the quality of the existing lines and also the demand that the new turbos require. would want to starve them of oil and, if needed, water.
its for the styling if you replace them with braided. what kinda turbo's are you planning on running. Replace the bolts, and don't forget a good new gasket set from nissan, these are highly recommended.
I replace as much as I can, so when I need to play with it again, i don't have to go through working with rusted or stretched bolts and rounded nuts.
- All gaskets should be OEM Nissan where possible
- New manifold studs, and nuts (lube when torqueing to prevent over tightening, and use (I fabricate) metal tabs to bend over the nut to prevent loosening.
- I too recommend investing some coin on race fittings and braid. Don’t be tempted with knock off Korean stuff, stick to Speedflow, Earls etc. Swivel fittings will help with setting up the pipe runs.
- Don’t forget shield from heat, and abrasion. Small gauge braided line will cut through anything if left to rub on it long enough.
- Unfortunately many people use race fittings simply cus they look shite hot, but I reckon they should be used to speeden up and secure, the disconnect / connecting of lines. They'll minimize leaks and of course last longer. Keep in mind these attributes and use them to improve Nissan's original design (my modifying mantra :P
- Notice the way Nissan design the water feed for the turbos for instance. Its taken from the interior heater hose (A) (back of motor, drivers side firewall) comes round passenger side, round front of motor and empties on nipple near thermostat (B) In between those two points, waters "T'd" off for the turbos. Clearly this was designed so that water flowing through the lines that run close to the manifold doesn’t get heated up while waiting to go through the turbo; there’s a continued loop of coolant, always providing the cartridges at "close to" engine temp.
- You'll notice the pain and hassle of removing perished rubber hoses, dodgey wire and compression clamps off; replace hoses and fit good quality worm driven clamps, and "T-bolt" clamps for larger bore pipes. (If I cant find a worm drive clamp im familiar with, I buy one, take it home and torque it till it skips a tooth... all aren't made equal) Out of habit, I double clamp critical pressure / vacuum hoses
- Good time to degrease blowby oil from all piping (Degreaser soak then meth / Kero mix)
Hope it helps
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
