I lost my clutch today and have found it to be a leaking. It is leaking where the rod from my pedal goes into the firewall and the fluid is slowly leaking inside the car. Is there a seal up there where the rod goes in I can replace? If not what is the course of action to remedy this problem. With a bleed and a refill every other day it is still useable but I do wish to fix it.
https://www.sau.com.au/forums/topic/186124-leaking-slaveclutch-pedal/
get it fixed a soon as you can. not good to have brake/clutch fluid running into you car. ruins your carpet and eats up paint, nasty stuff to have leaking everywhere. but yeah they are about $100 to $120, takes about 45min to an hour to swap by yourself. easy to do aswell. you could get it rebuilt and seals changed but its easier to just get a new one.
If it's leaking inside the cabin its's your clutch slave cylinder. You can get genuine Nissan ones for around $96 (R32) but if you wanted to do it on the cheaper side you can pick up second hand R31 parts for cheap. When my slave was gone i also had to overhaul the master cylinder aswell.
Good Luck :P
Good Luck :thumbsup:
You have it arse about. :(
If its leaking inside the cabin its the master cylinder. You check if the slave is leaking by lifting the boot on the slave cylinder.
I've replaced mine with aftermarket items in the past. The slave has been good and cost me $38.
I tend to go through an aftermarket master cylinder once every 1-1.5years or approx 30,000km's. The master cylinders are ~$75.
With a std clutch the aftermarket would probably be fine; I run a clutch that feels like the brake pedal. :S
I had my master cylinder go a couple weeks ago. Ended up having to drive with no clutch for 2-3 weeks. Got real good at it aswell. Only proplem is having to turn off your car and start it in gear everytime you come to a stop. Was embarassing at first but got over it. lol.
  • 4 weeks later...
Stoked to find this thread. Mines been doing this for ages but only just realised its leaking in the car :D
LOL mine hasn't got that bad. Mines a once a month or so job. Good to hear doesn't sound like a major problem :)
Just for future reference for anyone searching this topic. Mine WAS the clutch master cylinder and the part cost me $110 from Just Jap.
Including installation depending on labour charge 2 hours MAX you should be charged.. pretty simple job :D
  • 3 months later...
If your just replacing the clutch master cylinder, you dont have to bleed all the fluid do you? Is there any certain procedures needed to be made to reduce the amount of air entering the system?
  • 10 months later...
Yes rebleed whole hydraulic clutch system.
Does anyone know where I can find these aftermarket clutch master cylinders in sydney? And prices?
Does a new r31/VL master fit 32?
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
