Hey all, I've decided it's the right time to sell my baby. Why the low price? I dont want it sitting around for ever. price is negotiable if you are serious.
Also on carsales
Details are as follows
Sk's Bilstein circlip height adjustable suspension with whiteline uprated springs, fitted approx 1000km agp
18x8.5/9.5 Staggered Starcorp Impuls with Nankang NSII tyres, 235/40 fronts 265/35 rears, fitted at same time as suspension
Nismo 1.5 way LSD
Powerfc with Hand controller, tuned by Matt Spry @ PITS performance to 240rwhp @ 12psi
Apexi AVC-R boost controller
Razo turbo timer
HKS pod filter
HKS blow off valve with plumb back adapter included (not currently fitted)
JJR split dump pipe (plumb back but you can still hear the wastegate!), high flow cat, Kakimoto cat back 3” exhaust
Recaro driver’s seat
Pioneer Bluetooth headunit with integrated handsfree and Ipod control
Wheel well mounted 12” pioneer subwoofer
Full NIsmo body kit
Relatively rare in Red
First owner ex Japan
Absolutely brilliant to drive, perfectly balanced between power/handling/comfort, but also a great base for modification if desired. Serviced every 5000km with Fuchs Lubricants, always run on BP Ultimate. Much loved but fiancé says it’s time to upgrade to a more “mature” car. Like a 350z with 20's :thumbsup:
If you would like any specific pics just ask and I will take them for you.
U keen on tarding with an 06 BF XR6T 6sp manual with 12,000kms on it!! A few little extras as well:)
https://www.sau.com.au/forums/topic/186136-sold/#findComment-3366360
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
