Oil sits about 110degrees when ur ontrack
about 90 with decent airflow and casual/semi spirted driving on a 25 degree day.. obviously fuctuates during hotter temps.
Water I have no idea..
On the subject i think my r34 coolent/engine temp sensor is crap and the gauage is showing normal all the time when I suspect it is not this way.. Anyone know of a cheap measuring tool to monitor real temps?
Best bet I think, would just be install a water guage, they're handy to have in the car anyhow.
oil temp cruising sits usualy 10-15deg hotter. on the track can get up to 150 if yoyr trying hard
thats really bad because oil breaks down at around the 130 degrees mark... This can cause catastrophic failure
As a comparison, RB25DET in my 180sx which still retains the air con condensor (no room for a clutch fan)
Water Assistance = Nismo thermostat, twin SPAL 12" Thermo's, Koyo 53mm Radiator, Pivot Fan controller
Oil Assistance = Greddy Oil Cooler.
Retain the lower splash/air diversion plastic shielding - it works.
Power FC water temp reading = 75 degrees
Pivot Fan Controller water temp reading = 78 degrees (seperate sensor is within 5cm's of the factory water temp sensor)
Defi Oil temp gauge shows 82 - 85 oil temp.
Also you're in Brisbane like me, so half of the figures from members on this board are significantly different to ours due to the cooler conditions on average.
  • 4 weeks later...
  • 1 month later...
So 80-85 degrees water temp is normal operating engine tamp for RBs, right? I got electrical fans and 2 step switch. 1 step is at 84 degrees. I thought it was too low some how )) Maybe I would get a better mileage with higher water temp ?
