ive bought a fire extinguisher for when i do track days but i cant think of where to mount the bracket. i want it in there all the time, not just for track days so its got to be functional.
i was thinking of mounting it on a piece of metal that i'd put between the front 2 bolts of the seat rail. the drivers side looks easiest, the passenger side is a bit uneven so mounting it might be a problem.
having it on the drivers side will restrict how far forward i can put my seat, although i do drive with my seat all the way back on the rail which isnt too much of a problem.
does anyone have any hints or ideas on where to mount the fire extinguisher, pictures would be handy.
https://www.sau.com.au/forums/topic/186175-where-to-mount-fire-extinguisher/
thanks.
first link is useless. the link in it doesnt work anymore.
2nd link is what i had in mind, but the r33 rails arent straight across on the passenger side, one comes up on an angle so it will look a bit aquard.
I've mounted mine on the passenger side, only because the Bride seat mount doesn't permit it on the driver's side. Strip of flat Aluminium mounted between the seat bolts.
Joe,
Ive got mine mounted passenger footwell - the bracket is on the plastic bit that is infront of where the ECU is
:laugh:
doesnt cams require the fire extinguisher to be in reaching distance from the drivers seat?
ive thought about that, but i dont think it would be approved/safe if it wasnt within reaching distance. like what was said in one of the threads beer baron linked: the last thing you want is to be upside down, locked into your seat belt, smelling something burning and not being able to reach your fire extinguisher.
i've been in a situation where a fire extinguisher helped slow down the burning of a car which bought us some time to get people out/away from the car that rolled over and lit up. thats why im being overly cautious about where i want it mounted (nice and close), not just to meet regulations.
good points!
Most of the stuff I do though you can have passengers in so they can reach it :( and the CAMS events I have done there hasnt been an issue where its been mounted
but now you have me thinking - perhaps just behind you mounted on the drivetrain "hump" thingy! otherwise Im all out of ideas!
this is all you need. simple, easy to reach, meets approval from cams scrutineers, easy to make. Plus it's very sold as the last thing you want is it coming loose in an accident. chubbs, mounting it to plastic interior parts is a bad idea. can you imagine what two kilos of steel will feel like it it hits you at 100km/h! not good.
Never been "pinged" in scrutineering with the extinguisher in front of the passenger seat.
As I said, it won't mount in front of the driver's seat because of the way the Bride adjustment works.
Mine sits neatly along the passenger side foot well, behind the ecu, under the door opening. I can reach it from my seat with my seatbelt on, and its out of the way. And its screwed into the body of the car so it wont fly off.
Mine is 'under' my drivers seat. Fits in nice and tight. Seat goes all the way back, and all the way forward. Its not coming loose at all. Cant be seen from outside the car, where I have my seat anyway.
Thats in a Ceffy tho. It does have R33 seats in it.
Nice pics!
As secure as possible is all I'll add, I'd be bolting rather than relying on tappers et al. German cars tend to have the extinguisher under a drivers legs, do what best suits you.
CAMS requires a warning triangle, I suggest the Euro or UN variety, accepted under AUS Standard, AND is the better performing product in night reflector and daytime inner triangle fluroescence. See Sig example.
OT a bit: High visibility safety vest used by roadside at crash scenes and breakdowns to EN471 (EU and world standard) or AS cost as little as $6-00, further cheap insurance.
    • Looks like they've been through a few versions of the kit; that is not the one I had trouble with (it had the level sender attached to baffles on the floor, the one you linked the level sender is hung from the hat). One obvious point about that kit is it has no baffles at all, not even the factory setup (although it looks like you can retain the factory setup if you want).  Not sure if that will be an issue or not, the good news is it looks like you can get the pump nice and low in the tank, but that doesn't help if the fuel is all sloshing to one side of a wide flat tank
    • One more question if you don't mind. Is the first kit you tried the same one as they currently sell as their fuel-pump-hanger kit? https://frenchysperformancegarage.com/collections/fuel-system-kits/products/fpg-bnr32-fuel-pump-hanger-kit-single-fits-stagea-c34-nissan-skyline-gt-r-r32-fpg-087?variant=42131478315186 Because according to their video the low fuel warning thing can be taken from the OEM hanger and attached to their new hanger. Just wondering whether this is the kit you weren't happy with, or whether it's a different revision. Thanks again!
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
