tabs?
Yes the ability to set the starting placement of a word etc.
EG
a) 1 1
b) 1..........1
(a) should have the same starting places as line (b) but this forum automatically removes excess spaces.
Edited by a20089
Like this?
First, make sure in your board settings you are using the rich text editor and not the standard one.
Second, dont use quick reply.
Third, click the button, 6th from the right on the second row above the text area...
alternatively, use 'indent' tags. ie
[indent][/indent]
ohhh those tabs...
can you use
indent tags
halfway though a sentence?
I could not get indent to work across multiple spaces
eg frank........GTST......... 1min 30sec
Frank
GTST
1min 30 sec
How can I get the above to work on one line?
Hey Prank, when do I get my donation tag? Not pushing or anything
:P Edited by a20089
Prank, even using full rich text editor dosen't work as it strips the tab spaces out and replaces them with a single space.
The only way to post up a table is to use HTML, which is disabled on the forum for security reasons.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
