  • Replies 236
*Bluprint has fond memories of Leshy turning up 2 years ago and leaving his car there, then coming back near the end of the show after going home for a nap
Hey, I was really really hung over that day, give me a break.
Also my car is not a skyline, sorry to burst the 30 car bubble.
With the Count just there and ppl having non Skylines in the list, I now have the tune "one of these things is not like the others...." from Playschool in my head ;)
Edited by sl33py
CeJay
S T A R 3 3
Baconer
Tuk Tuk
LadyBytes
Bluprint
a20089
mrgilly
Turismo
zenith13
sigsputnik
Frink
Bullet32
zooee (Rob)
BNR32t
datto260z
Donnan
MANG
stunnd
SL33KY
Psymon
widebody32
sl33py (Ben)
Glenieboy
R33Driftr
IB6UB9
JD-33
stinkypoo
ok, 28! 28 skylines at the marques in the park! Not quite as good as 30! Ah ha ha ha!
CeJay
S T A R 3 3
Baconer
Tuk Tuk
LadyBytes
Bluprint
a20089
mrgilly
Turismo
zenith13
sigsputnik
Frink
Bullet32
zooee (Rob)
BNR32t
datto260z
Donnan
MANG
stunnd
SL33KY
Psymon
widebody32
sl33py (Ben)
Glenieboy
R33Driftr
IB6UB9
JD-33
stinkypoo
I've heard of people putting there 32 headlights in the oven, to seperate the glass from the plastic backing to modify the lights etc, don't think you could do it with the indicators though.
4 weeks Till Marques in the park btw.
Yeah, I've also heard either oven or a heat gun to seperate the glass from the lighting assembly, then I guess you just glue it all back together when you're done
Edited by Bluprint
The soarer ones were the same deal. Don't do what my mate did and forget :P
Thanks guys,
I'll have a go with a heat gun first, I dont really like the idea of putting $200+ indicators in the oven...
bullet32 go and buy some Meguiars PlaticX (http://www.meguiars.com/?clear-plastic-care/PlastX-Clear-Plastic-Cleaner-Polish) and use that. I use it. Works wonders... just make sure as soon as you ploish it on POLISH IT OFF ,, it tends to stay on otherwise.
JD
Edited by JD-33
For once I'm prepared! All booked in with Details FX :P
hmm went to them last year and was not impressed. They did great work on "what you can see" i.e. main panels.. but they did not do the "nooks and crannys" .. eg when you open your boot the side of the boot wing,, the engine bay was a dissapointment too.. just my 2c
the best place to go is the place down the back of the shell servo in Woden. They do an awesome job, best detaillling ive ever seen. Though my car (and prob many other liners) can make it down their steep driveway (due to low front bars) :(
JD
Edited by JD-33
the best place to go is the place down the back of the shell servo in Woden. They do an awesome job, best detaillling ive ever seen. Though my car (and prob many other liners) can make it down their steep driveway (due to low front bars) :P
JD
Are you sure your not talking of details fx in your second post they would be in that general area ??? I found the work they did on my skyline and forester was unreal on the surface but i agree they could have paid a little closer attention to some of the nooks and cranny's
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
