Someone tell Jon how big my BBQ is... welcome to use it, but can only take it if I get a volunteer with a ute and help lift it on and off. Its stainless steel with verrreee thickand heavy SS plates.
If we have to have PL anyway, then perhaps we could apply to sell food on the day.
Sounds like mine. OK scratch that great idea. Who's got a portable BBQ???
  • Replies 236
Just had a quick chat to Bruce about this. Looks like we will probably be close to where we were last year. With the celicas and mr2's but instead of being in the horshoe area be closer to the mustangs. The Federal tent with signage is ok. Have been told you cannot sell food to the public as there are already food vendors there, if we want we can setup a BBQ but can only sell the food to sau people etc. Need to make sure the gas bottle if there is one is legal, if not we may end up getting fined by the ACT park rangers. Bruce will be doing up a map a week or so before the event to finalise the areas. Will send an email to Bruce with details of how many are attending, progressively.
NOTE: The sale of food or drinks by clubs to Visitors to Marques in the Park is prohibited without the prior approval of the event director.
Does this mean we can apply for approval? Sounds like we already need Public Liability insurance.
If we want to I could ask but bruce basically said we couldnt since they have a bbq as there were already food vendors there, sounds like we would have to pay for the privilidge.
Hey CeJay!
Inspired by this thread of yours, I put one up on NissanSilvia a little while ago here -
http://www.nissansilvia.com/forums/index.p...howtopic=261653
The attendance is no where as many as listed here (yet), but was thinking, how about having the silvia's next the skylines on the day? :spank:
Edited by Ecstasy
Hey CeJay!
Thanks for the link, I posted there. Probably best to contact bruce if NS hasn't been there before as a group. So maybe he can organise a spot for everyone as a group before hand. I think he did say ther would be a nissan/datsun area. We may be all put there so to speak.
Just uploaded the skyline book, if someone wants to have a look over it and point out anything wrong with it or what needs to be added. That'd be great. Thanks to cef11e for organising it.
skyline_book_rev.doc
CeJay
S T A R 3 3
Baconer
Tuk Tuk
LadyBytes
Bluprint
a20089
mrgilly
Ecstasy
Turismo
zenith13
sigsputnik
Frink
Bullet32
zooee (Rob)
BNR32t
datto260z
Donnan
MANG
stunnd
SL33KY
Psymon
widebody32
sl33py (Ben)
Glenieboy
R33Driftr
IB6UB9
Cars back and i'm in.....
As they say in poker ..
"ALL IN"
CeJay
S T A R 3 3
Baconer
Tuk Tuk
LadyBytes
Bluprint
a20089
mrgilly
Ecstasy
Turismo
zenith13
sigsputnik
Frink
Bullet32
zooee (Rob)
BNR32t
datto260z
Donnan
MANG
stunnd
SL33KY
Psymon
widebody32
sl33py (Ben)
Glenieboy
R33Driftr
IB6UB9
JD-33
-JD
Looks Great mate, didn't notice any spelling or any other errors
Maybe at the "Z tune"
Or the older GTR's
other than that its really good.
CeJay
S T A R 3 3
Baconer
Tuk Tuk
LadyBytes
Bluprint
a20089
mrgilly
Ecstasy
Turismo
zenith13
sigsputnik
Frink
Bullet32
zooee (Rob)
BNR32t
datto260z
Donnan
MANG
stunnd
SL33KY
Psymon
widebody32
sl33py (Ben)
Glenieboy
R33Driftr
IB6UB9
JD-33
stinkypoo
Terminal
...and that, ladies and gents, is 30.
30! 30 skylines at the marques in the park! Ah ha ha ha!
Edited by sigsputnik
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
