sucking and blowing then swapping?
Wastegates actuators could be stuffed ie. the spring opening the wastegate at any pressure
To test that remove the hose running to the actuator and rev and see if it makes any more then 0psi
Edited by str00th
  • Replies 56
Posted Images
ok, well if theye are both sucking, and wooshing etc etc. then they work.
heres what to do next. you need to block off the blowoff valves. (the pipes that come up to the airflow meter pipes.) idealy you want to block them where the are. (drivers side brake duct)
this is just a random thing.. but i saw someone postin, that if 1 turbo dies.. it halves the boost???
just thought id let u know and everyone else that doesnt know, that twin turbos dont work like that.. 1 doesnt make 3.5psi and the other one another 3.5psi.. otherwise ud be able to run more than 14psi on a ceramic turbo.. they both make the same boost.. but because theres 2 turbos, the actual flow is twice as much.. so if one T28 makes 400cfm @ 7psi.. then two will make approximately 800cfm @ 7spi..
as for ur no boost... its not gonna be turbos.. i still think its ur bovs.. theyre sizeable enough to leak all ur boost, without stallin ur car (they are a valve after all..) what might be happening is a vacuum line going to ur bov's might have been severed.. They need pressure in the line to stay closed and then the pressure in the intercooler piping plus the vacuum in the vac lines (going to bov) opens them up during no throttle.. maybe theres no pressure in the "vac" line to keep it closed..
Shit hey 240?
I allways get ripped off. All well.
UPDATE TIME: Taken BOTH turbos out and to BUST all your bubbles it was the rear turbo. The exhaust wheel have come off and logded it self in the turbo. The front wheel wasn't turning nor was the rear. The shaft in the middle was snapped. Pretty f**ked up hey!
PICS come tomorrow. Such a relief that it was the turbos because i got abit worryed when everybody thinks it's something else. The wastegates were fine. Everything was fine. No leaks in the system no leaks in the BOV's. It was that turbo shaft that was f**ked.
All well. Now it's time for the INSTALL. Probly going to take as long if not longer. So far it's taken 7 hours to take them out...
yeah. bovs is the next logical step. ps.. with no vac lines hooked up it will still hold 10 pound :ninja:
no boost at all? does it sound abit funny out the exhaust? id be suspecting a ceramic turbo failed. ive had ones die on standard boost with no mods.
Shit hey 240?
:ninja:
UPDATE TIME
Finsihed putting the new turbos on. Thanks Hyperdrive Motorsport f**king legends! BOY O BOY the difference the new turbos make. The old ones must of been f**ked or piping isusses? Anyways did some upgrading of the old clamps, bolts, gaskets,nuts ect and the differnce is F**CKING AWESOME. Spool time is nearly instant and power pulls something curl! Another thing is i can here the blow off values heaps more now. Whats the go?
Blocked cat usually it will feel flat and retarded one blown turo will result in no boost what so ever and the symptoms you described cat is a remote possibility but being a GTR dave is going to be right in that its spat an exhaust wheel.
Hmmmm way back on page 1!!!!!!!!!!!!
Edited by Risking
Sorry if i didn't believe you guys way back on page1 but it is alot easier to remove your cat then to remove your turbo....
It's not making more boost becasue it's still making 0.8bar. Just feels alot more boost but not. Thanks guys.
<object width="425" height="350"> <param name="movie" value="
</param> <embed src="
type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
I made it to the show and shine in Geraldton on sunday. I did a dyno run and got 201 with winding out 4 and hitting the 180 limit. Theres the video!
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
