Hey everyone!
Guess lm one of the many suckers out there that fell for the glamour of going HID.
Well, l have a problem now and i hope you guys that have done it properly can help a guy thats blind at night out.
Heres the problem.
When l turn the lights on, the light is all concentrated on the side of the car and almost nothing can be seen in the middle of the road when driving. My range of sight has decreased to apprx 1 car space. Also, when lm waiting at the lights behind another vehicle, the headlights can barely be seen.
I have a Philips 6k HID kit on a S1 R33 GTS4 (Non projector-Halogon covers)
What can l do to angle the lights into the middle? Ive heard lm suppose to turn the hex nuts but they havent really helped. Also, when l installed the hit, l removed the metal plating which was used to hold the old halogen H1 bulbs.
Any pics on adjustments will be great, also, my headlights arent angled too high or too low, and also, there are no hotspots since lights not even directed in the middle.
HELP OUT PLEASE!!
https://www.sau.com.au/forums/topic/186219-hid-problem/
Hey everyone!
Heres the problem.
HELP OUT PLEASE!!
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3367248
Hey everyone!
Heres the problem.
HELP OUT PLEASE!!
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3367291
Never having owned a r33 I'm not 100% sure however I would firstly check the HID conversion kit bulbs you bought are the same ones that came out (i.e. h4 came out then the bulb should say h4, the hid kit should also say h4). This wlll establish the bulbs are aligned correctly with the assembly.
I should also say that the only aftermarket HID kits i've seen work are ones with r32/s13/a31 projectors. I've never seen r33's look good with HID. The headlamp assembly just isn't designed for it... having said that I'm sure someone has got it working better than what you're describing but you won't ever get rid of flares and hot spots with them as far as I know.
You should do a retrofit if you want to have the best result.
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3367319
Can anyone, whos done this help me just get the light into the middle of the road, that would be highly appreciated.
But yeh, l just wanna try it out and see how it goes, if its ok, stick with it, if not, back to halogens l guess, retrofit is to hard inside the rectangular reflector.
Does anyone else have ideas in which i can fix it up?
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3367330
Howdy mate,
I have the exact same car as you and I can tell my HIDs are amazing... they have made such a diff at night... especially driving on the Monash freeway.... so much brighter and clearer...
I must warn you though... with HIDs... no matter how low I point them I get people flashing me atleast 2 -5 times a night and some people like to chase ... which can be a little scary at first... ( but now its more like catch me if you can :P )
Now to fix your prob.. I hope you have checked around this site for how to adjust your headlights.. cuz I had to learn how to make mine lower and then more bias to the left...
You are aware there should be two sets of those nuts somewhere? one for up and down.. one for left and right? Mayb you are adjusting the wrong ones?
If your near the chaddy area be happy to show you what a white set look like on a skyline...SXC!
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3367403
Sorry dude, there is no way you'll be able to concentrate the light to the correct spot
it'll have hotspots and glare with almost anything to you do to it
The only way to properly fix it is to install HID projectors, I've bought a set of 4x FX45 ones for mine, with high/low in each lense and I'm making custom clear perspex covers.
It's the only way to go sorry man, check out Ronins HID thread, do a search for HID Conversion and you'll find his, he's done a nice job
or check out HIDplanet.com/forums
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3367481
Do what skybarge has suggested. An HID kit in a reflector housing is just stupid in my opinion. Even HID kits in projectors made for halogens are stupid (yes, I know I've got some, but I regret buying them :mellow: ).
There should be two hexagon style bolts behind each headlight. One should adjust where the beam goes up and down, the other left to right. Play around with both to find out which one goes from left to right and adjust it properly. You've got to turn them at least 5 times to notice something so don't just turn it once and give up because 'they don't work'.
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3367794
To person saying hids never look good on 33s..
Well my friend has an MTEC (apparantly jap brand?) kit in his 33.. and they look awesome..
Never experienced his only pointing one way etc?
And its bright as well..
Maybe i should ask him to post a pic (his car is a s2 33)
Anyways im sure the cheaper brand hids will probably expeirence the problems you are describing..
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3367853
haha yeah you can see the hotspot in the middle :S
that's what mine were doing, bought two kits :( oh well you live and learn
just recieved 4x bi-xenon projectors, so I'll write a tutorial up soon :rofl: kind of like ronins, but with twin HID projectors, custom shrouds, hopefully plastic metalized to get the chrome look, then with custom perspex covers :)
Be good to finally get them done, just waiting for some more $$$ :D
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3368306
just recieved 4x bi-xenon projectors, so I'll write a tutorial up soon :D kind of like ronins, but with twin HID projectors, custom shrouds, hopefully plastic metalized to get the chrome look, then with custom perspex covers :)
Be good to finally get them done, just waiting for some more $$$ :(
Surprisingly, I haven't been flashed once.
Keep us updated on your project mate. I want to see what 4 bi-xenons look like on a 32. I wouldn't like to get flashed by you >_<
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3369159
Hey everyone,
My passenger side of the HID has been set correct from playing around with the 8mm hex bolts, but no mattr how long l tinker wif the driver side, it wont friggin budge, l can adjust the height, but the light always points directly into oncoming traffic, ie (right side instead of in the centre).
I'm contemplating removing the headlight and playing around with that.
Also, the height is adjusted fine but l get no light at all directed towards the ground from driver side, i think there might be a problem with the bulb.
Does anyone know where i can get a cheap replacement bulb?
Cheers
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3370808
Yeah Adam is right,
The reason you are getting the glare/hotspots is because your bulb is too far from the lense in the halogen style setup, the lense is a different shape from an HID lense and your glass headlight cover has flutes in it.
I'm creating plastic lenses with no flutes(lines) in them, to try and get rid of all hotspots,
I've gone for 4 OEM projectors out of a Nissan Murano, which after a bit of cutting are nearly fitting in the standard headlights:
The second one is too far forward in this photo, it needs some cutting
Not quite even here, but you can see how clear the HID lenses are and how small they are, most halogen ones are quite large and pretty flat when you look at them sideways, these are about twice as thick as my old ones
This is the old shroud, which I'm keeping, basically creating another circle where the rectangle hole is out of plastic, in the same shape as the circle on the right, then off to the plastic metalizer to get chromed
I should have it done in a few months, after I've paid off some bills, so I'll post up a full tutorial of it, you can always keep the hid kits for now, then later on when you want to retrofit, buy the projectors, then get a D2S or D2R bulb to suit the HID projector and use the kits ballast to keep costs down, or sell it and buy an OEM ballast and bulb
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3372422
Looking good so far mate.
Now that we're on the topic of projectors, how large are the standard projectors? I keep getting the number 2.5" in my head, but not sure if that's the size of the honda euro's projectors or the skylines.
For those that don't know what a retrofit headlight can look like, here are some examples taken from hidplanet.com. Compare them to my headlights with the hid kits.
These are the specs of what was done to those headlights:
Acura TL Bi-xenon projectors
BMW E46 (ZKW) clear lens swap
4300k OEM Philips D2S capsules
OEM Hella Gen 3/Philips LVQ-212 ballasts
More examples.
The specs of those lights are:
Acura TSX projectors
(2) #8 washer colormodded
OEM Philips 4300k capsules
Who wants to do a retrofit instead of buying cheap hid kits? I do!! :D
https://www.sau.com.au/forums/topic/186219-hid-problem/#findComment-3372773
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
