hey guys
i have a new problem
- when i stop at lights or slow right down to do a U turn or something it will just stall/turn off every now and then not all the time but is more occuring as i got it home
- in boost its rough and jerky? like its not boosting right or something?
i cant see any vaccum leaks it has a aftermarket wold 3d v4 computer in it could this be causing any of these problems?
i had the blow off valve come off its housing the other day if thats of any help but i really need help i have no idea ive only had this car since thursday
even a list of things it coudl be would be helpful
any help is good thanks
Josh
Stock BOV? If not, its not plumb back is it?
Either way, I think you definitely have a boost leak, especially if your BOV came off its housing... (Can you supply more info here?).
it still starts tho and the BOV is still on
as u may or may not know i had the BOV come off on me so it could be leaking thruogh that?
basicly if i pull that loud shit BOV off and put a standard one on i might fix all my issues. Is that what ur saying?
the bov seems pritty tight on there and it wasn't acting like this before i blew it off the housing?
does the boost leak explain why it randomly stalls in idle and when left idleing it may just stall every now and then after a while
when i turned it back one once or twice it just stalle straight away then i turned it bck on and it came close to stalling twice before returning to normal idle? (has done that twice, once with only me and once when showing my bro my issues after gettng him out of bed to drive to my house and have a look lol)
its GFB BOV and yea it is venting to the atmosphere (not plumb back)
what other info do u need to give a better idea on things?
(off to bed will check topic in morning for updates)
Josh
Edited by -BORED-
How much boost you running? when I hit 15-16psi My standard fuel pump does not like it. and jerks me around and I lose complete power. also makes me look stupid, so I envested in turnning the boost down a tad. :mellow:
It sounds like you've a got a leak somewhere mate. When there's a leak, it would be harder for the car to idle properly after start-up and it would stall when you slow down(to do a U-turn for example).
gonna change the BOV
just buoght the brand new turbo smart dual port BOV and the adaptor plate for a R32 and the plumb back port needed to be taken off and a plate they have put over it so i undo 3 of the screws and the 4th one was really really tight... that tight the head snaped off the screw :( cant take it back till thursday night cus of work.
but if that doesn't fix my issues i dunno i cant see where it could be leaking? ive looked at all the pipes couldn't find anywhere with a cut or nick or anything everything seems nice and tight
Josh
its not the blow of valve
how can the bov make a car stall at a high vacuum idle
look at it this way a petrol engine creates vacuum between the throttle butterfly and the valves, now seeing that the bov isnt between the throttle butterfly and the valves how can it be a faulty bov
possibly the vac line to it but its fine and no holes in it.
he has gone out and spent 500 odd $ on a bov he dosnt need because he had people posting that didnt know what they were on about
if you dont understand what is going on DONT POST
Could be inlet gasket on the plenum or leaking injector,
Check by spraying carb cleaner around plenum / injectors and see if the engine revs build / drop.
Standard gaskets on the inlet are renowmed for leaking, put metal ones on :domokun: Or you will be doing it again.
Kev
mine has the exact same problem, i checked it out and found a broken fitting connecting the bov to the vacuum line, so i replaced it with a new bov and started it up and left it idling for a few minutes then took it for a drive and 30 minutes later its doing the same thing again, boost is realy jerky and it feels like there is no power. chews fuel real bad too. ??? :down: . my new bov is a hks super sqv so its not like its something cheap from supercrap
In a map sensor application it doesn't matter if it's plumbed back or atmo as there is no air flow meter. The ecu uses the TPS and map sensor as it's primary inputs. dumping air out on gear changes doesn't matter to it.
For todd, the bov issue referred to by the rest of the clowns in this thread is caused by the extra fuel that is being put into the cylinder as a result of the atmo bov dumping metered air in an afm equiped situation. basically, air comes in afm say's you have x amount of air, ecu says ok, i'll put in y amount of fuel, bov dumps most of the air, super rich stall inducing mixtures.
On to the problem(s);
I think you have 2 separate issues, 1) the return to idle tune is up to shit and needs to be looked at. As with the bov, a vacuum leak in this situation won't cause you to stall. I'd suggest going to see a tuner who is familiar with this type of ecu and get him to take the car for a drive and see for himself. If it's stalling some of the time, i expect it is overshooting the idle revs on decel all the time and dropping to 3-400 regularly which it shouldn't do either. 2) the surging on acceleration is possibly coils, possibly a dodgy highflow (i don't know what sort of turbo you have), possibly dying fuel pump. Again, if you go and see a tuner and get the car run up on the dyno you can check for fuel, you can hear compressor surge, you can hear and see missfires.
ur all wrong!!!
if u eva need help just take it to someone who knows there shit dont waste ya time with this they wont charge u for a little advice
vac leak? boost leak? nope
tune + spark plugs = all good
still has a little crazy idle but that is gonna get looked at at a later date as its no longer stalling and he said it is now good to go come back in a few weeks if the idle is still over correcting itself so much
most likly the little motor that controls it because he said he knows its now nothing to do with tune
Josh
