Screamer Dump Pipe
polishboi
 Share
  • Replies 70
Just have a split-dump made, and dont plumb the wastegate pipe in... and thats that.
Although, its going to sound exceptionally poor with a small turbo/internal gate.
It will also most likely leak at idle aswell, so ye. Go for your life, just dont be disappointed when its not what you expect :P
if ur going to use it on a internal gate turbo its going to sound like a big exhaust leak
It will have a small exhaust leak sound at idle but when the car comes onto boost........WOW its REALLY LOUD.
Greenline have nightpager screamer pipes listed
If the exhaust/wastegate is designed well and works (flows), a screamer offers nothing but noise. No performance gain what so ever
so ur saying a almost instant free flowing wastegate will produce no advantages? i get this by basicly comparing it to a 1inch pipe that ports back into the exhaust. there defiently would be restrictions there???
i woulda thought it would at least defiantly hold boost better.
again correct me if im wrong.....
so... how is a screamer dump pipe different to a dump pipe??? i take it a dump pipe pushes wastegate gases through the exhaust system and the screamer pipe will blow it directly into atmosphere, which would make more power and noise but would be illegal... is that right
I have an external wastegate HKS. I had a screamer pipe and sounded really loud. I felt like I am looking for trouble plus...was all noise, was so loud you had to back off the accelerator after 6psi boost. I had made a new downpipe and plumed in. Noise gone and car runs much better.
Now I go close to 20 psi sometimes(instance). I think is cool to have performance no noise. If you look for noise take your exhaust off...will be same thing!!!! I don't think you gain any power. I lost nothing pluming in!
Just a thought, you can ignore it!!!
Eug.
As i said before.
If the exhaust is free flowing enough, then it wont make a difference.
Having a dump (with a int gate feed/split dump) or screamer is no different really.
The air is physically still coming out of the same wastegate hole size, that doesnt change. So i cant see how its going to affect boost pressure when the gate size doesnt change, not the air passing by it.
do screamer pipes on ext wastgates have any effect on performance?
Definitely. The gas going out the gate doesn't go through the exhaust -
more "space" for the gas spinning the turbo (basically, any time the
gate is open there is less backpressure than there would be with a
plumb-back).
Also, the bled gas is only pushing against atmospheric pressure, not
what's already in the exhaust (basically, a given gate size can bleed more
gas; or same gas at lower duty cycle; or smaller gate can handle same
bleed requirement to maintain boost).
correct me if im wrong but dont screamer pipes spool quicker and hold boost better
won't spool quicker (the gate has no effect till it's opened).
Might hold boost better where the gate is too small - a plumbed-back gate will be
able to bleed off less gas than the same size gate opened to atmosphere. Better
to get the right-size gate.
Regards,
Saliya
Edited by saliya
 Share
