Hi guys,
I'm after a bit of advice, I have an r32 gts-t (93), I have noticed my factory oil pressure guage reads quite low (nearly back to 0 on idle, and only just above 2 for normal driving), is this likely to be an oil press sender issue? It runs fine, plenty of oil etc...
Also another quick question, I occasionally get a small hesitation when I roll off and back on the throttle, as in, I back off slightly, and then when I squeeze the pedal back on it gives a small miss, and then pulls away fine, not the end of the world, but it never used to do it.
Any help would be great!
Cheers.
https://www.sau.com.au/forums/topic/186241-r32-oil-pressure/
Hi guys,
Cheers.
Oil pressure Sender units are notorious for giving up the ghost, have someone check your oil pressure with a mechanical gauge. Flat spots are generally caused by a lean mixture, you may have an air leak into the inlet manifold.
...I have noticed my factory oil pressure guage reads quite low (nearly back to 0 on idle, and only just above 2 for normal driving),
I notice the exact same thing with mine, could it be normal for a R32 GTS-T. My oil pressure does however rise to 4 after it has fully warmed up though.
My motors healthy (compression tested etc..) but the oil pressure gauge always reads low.
On start up when cold it will be just under '4' on the stock oil pressure gauge, and it only gets lower as it gets warmer.
When cruising at a consistant speed its quiet low, but at about 100km/3XXXrpm its in between '2' & '4'..
I don't really worry about it to much as I have been told the stock oil pressure gauge is useless, so I won't be able to get an accurate reading till I get a decent after-market oil pressure gauge.
i also notice the guage gets lazy around oil change time(5000kms)
Yeah mine went heaps low after I serviced it.
Was slightly worried with it being so low..
Edited by abu
Hi again all,
Well I have fixed the problem, turned out to be an interesting one!
I had just replaced oil and filter before I started having this problem, and I used penzoil 10w30, which was a mineral oil, and as I read some of the posts is not the stuff to use, so I went to supercheap and got some fuchs 10w30 synthetic and chucked that in just to be safe.
Took her for a drive, and to my surprise, oil pressure is now back to normal readings on the guage! Not sure how that works being the same viscosity of oil and all, but thats how it hapened!
Cheers,
Rosco.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
