Hey all
just posting some pics and stats about where my car is at
180sx with an RB20 conversion
^^^^ this is her before. CA18, Apexi Power FC, manual conversion, GT3037r, Tial 48?mm external wastegate, 700cc SARD injectors, custom manifold, FMIC, 040 in tank, half inch fuel feed, pres. reg, custom 3" down pipe and front pipe in one into a 2.5" exhaust straight through, front strut brace, oil catch can, Exedy heavy duty cusion brass button clutch, screamer pipe :( my first ever car project.
^^^^ this is her with the CA out getting prepped to have the RB dropped in.
^^^^ RB20 sitting at Dannys on his floor, waiting to be put in. Looks clean. Has done 5X,XXXKMs
^^^^ GT3037r sitting atop a Hybrid custom exhaust manifold :D and sporting the sweet ass Tial 48?mm external wastegate
^^^^ RB sitting in the engine bay :D with the GT3037r. fits perfectly. i'm so stoked
^^^^ ...Trying to be creative, camera phones.
For the moment it'll remain stock, cept for the turbo (going to run low boost) and i'll need 3" cat back piping - got 2.5" atm, get enough cash for a computer. Then the custom inlet plenum will go on (thanks Mick!), and hopefully a set of 700cc or 800cc injectors - to set the long term level. Then a tune, and possibly some larger cams :D also getting a VL radiator put in now.
Going to spray it, either myself or get a pro, Mat red. (any thoughts on the colour? the rims have a white insert. posted a pic just below) work meisters on hold, 17", should hold nicely, depending on the rubber i've got i guess
^^^^ Work Meister SP1 2P 17" 225s front 235s rear i think, not to informed on tyre/wheel specs :mellow:
some window tint and we're laughing haha
^^^^ here's a pic of my car btw. Anyone good at photoshop? Mat red with the Work Meister wheels???
hope to have it all done around the new year, bit after maybe :) hopefully at least sprayed and slammed before autosalon
cheers. i'll post more up when she's out and ripping! wednesday at the latest i'd say :D
Edited by RB- ajsx
https://www.sau.com.au/forums/topic/186248-second-begining/
Awsome dude. Just a question and not intended to insult, but why a RB20 over a SR20 or RB25? I guess i say this because of the SR having more torque and less weight due to 4 cylinders and same displacement and the RB25 speaks for itself but is the same engine with more of everything? But its looking good dude and im sure it will still haul arse.
https://www.sau.com.au/forums/topic/186248-second-begining/#findComment-3369945
RB20's are a good motor. they are cheap and fairly easy to get your hands on. same for parts too. they are strong enough to handle a good amount of power and i reckon they have wicked sounding exhaust note....
https://www.sau.com.au/forums/topic/186248-second-begining/#findComment-3370193
haha yeah datto, exactically what frink said :domokun:
personally i've always seen the rb20 as an underrated motor. it has a lot of potential. from my experiences the SR has been less torquey. but anyway, i see it has the potential to gain higher power than an SR, with fewer mods and cheaper budget, also one in good nick and set up well sounds evil!! haha
in the end all i'm after is a clean setup. both inside and out.
Oh and by the way, if you need tyres... I can help :D
might take you up on that two 235 17" street tyres? price??
went and dropped off the new thermostat today. should be on the road no later than thursday i'd say
...anyone keen for a cruise friday?? :P
Edited by RB- ajsx
https://www.sau.com.au/forums/topic/186248-second-begining/#findComment-3370356
Yeh cool. I guess they are easier to get power out of. I was just thinking that since RB25s are going relatively cheap nowadays and parts are relatively similar to RB20s in price and since you are doing the RB conversion anyways... But like i said dude, no offence intended and i reckon it will be sweet as anyways.
https://www.sau.com.au/forums/topic/186248-second-begining/#findComment-3370875
got her back and got her running as sweetly as i could without getting it tuned. will be soon though.
has a few bugs though, think the gearbox might be on it's way out. getting that checked out next week. minor exhaust leak, and a surge problem when hitting full boost but obviously i'm not doing that much till it's tuned and all set.
apart from that it's fun as f*** to drive!!!
;)torquey and sideways :thumbsup:
it's just as i'd planned and hoped it would be haha!
the gearbox is a bit noisey, very noisey actually. sounds like something is loose, but.. yeah haha. also hard to get into reverse and sometimes first. anyone else with an rb20 box experienced anything similar? maybe the clutch needs to be bled again??
i'll post pics up soon, and maybe a little vid on youtube or something!
:P
https://www.sau.com.au/forums/topic/186248-second-begining/#findComment-3409346
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
