In addition to that article..... this was a little snippet on news.com.au
A MAN was arrested after he crashed a stolen car into a fence at Ingle Farm last night.
Police spotted the stolen Nissan Skyline on Diranta Drive just after 9pm and gave chase when the driver failed to pull over.
The man crashed the car into a fence near Jakara Ave and fled on foot but was arrested soon after.
Hope it wasnt anyones line from here.
https://www.sau.com.au/forums/topic/186260-road-rage/#findComment-3368061
any good cars in teh sing
i agree on corpral punishment should never of been abolished
i copped a few good beatings it sort of turn out ok in the end :( didnt i ... cmon didnt I
EDIT
lol had to be from the northern suburbs
Edited by Madaz
https://www.sau.com.au/forums/topic/186260-road-rage/#findComment-3368292
This is crazy, capsicum spray??? FFS what do police carry guns for, if not to use them in cases like this, he should have been shot!
Coz then all the stinking, unwashed, hairy, peace-loving (at all costs), tree-hugging, alfalfa-munching, do-gooding, greeny anti-Police rodents will crawl out from under their organic-moss covered rocks complaining about excessive force and the tragedy of the innocent life stolen by jack-booted overzealous perpetrators of state-sponsored violence...
End of rant.
https://www.sau.com.au/forums/topic/186260-road-rage/#findComment-3368436
End of rant.
hahahah alfalfa munching, gold!
https://www.sau.com.au/forums/topic/186260-road-rage/#findComment-3369046
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
