Hey people
CAR: Nissan Skyline R33 GTS25T
MODS: Fmic, Bov, EBC, Air filter
After i installed my fmic it is now crunching in 5th. I has never cruched it 5th not really at high revs but aroung the 100km mark....................do you think is clutch problem, or do i need a fuel pump, or what .....
ideas need
https://www.sau.com.au/forums/topic/186274-crunch/
I doubt the FMIC install affected your crunching in 5th. Probably just a coincidence, does it do it every single time you shift into 5th? Try double clutching and see if it helps.
Also, what does a fuel pump have to do with your gears crunching? :mellow:
https://www.sau.com.au/forums/topic/186274-crunch/#findComment-3367858
I dunno about that the fuel pump has to do........just a thought
double clutch it ............... i know how to double clutch
but what double clutch in 5th
https://www.sau.com.au/forums/topic/186274-crunch/#findComment-3367880
how can your car idle at 6000rpm? do you mean 600rpm? coz 600 is normal.
NA NA NA NA SORRY BOYS
I MEANT 600
my idle needs to be a 750
reckon my idle need to be up
i was also told it might also be a spark plug problem
https://www.sau.com.au/forums/topic/186274-crunch/#findComment-3369895
You car idling at 600rpm has nothing to do with gears crunching in 5th dude.
It also (the crunching) has nothing to do with a FMIC.
5th crunching is the synchro's letting go or the clutch being a bit so-so possibly in some way.
Totally unrelated to the points you've raised here
https://www.sau.com.au/forums/topic/186274-crunch/#findComment-3370035
thank for that.................. Well i have Xtreme heavy duty cutch ....and my pedal is a bit high
this is wierd cause it only happen when it is above 100km not under
https://www.sau.com.au/forums/topic/186274-crunch/#findComment-3370161
just wear on you synchro's man. try double clutching as mentioned. i don't know enough to explain it, but it feels like releasing the clutch and then pushing it in again gives things a chance to align more nicely than doing the whole change in one motion.
e.g.
clutch > de-select 4th > neutral (clutch position same as when de-selecting 4th) > select 5th > release clutch [things haven't had a chance to re-align from a neutral point]
v
clutch > de-select 4th > release clutch > true neutral > clutch (fresh clutch engagement :P ) > select 5th > release clutch
[things have hit neutral without the clutch affecting it - the best starting point to select any gear. it's just a more box-friendly and often a more solid engagement]
remember 5th is also possibly the least 'sure holding' gear in your gearset and in worn boxes can just slip out of gear. think of it as if you're rock climbing and 5th is the last hand hold and you have to stretch and grab it with just the tips of your fingers... errm.. [note to self, shut the f*ck up with all these weird analogies you come up with!?!?]
Edited by made_guy
https://www.sau.com.au/forums/topic/186274-crunch/#findComment-3373582
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
