hey all, most knwo abotu my rebuild that has taken place over the past 8months etc.
finally got the car running on the run in tune on friday!
ands it rego'd rims are on and insured!
yes its safe to drive...
sounds pretty crazy tooo...
so if u see my gun-metal grey GTR on 19s with the plates URWSHN come chat or cruise!!
cannot wait till its run in and see what the final power figure is!!
im hoping for 400rwkw, turbos may be the only thing lacking now!!
anyways, enough from me! see everyone round soon, and im form the hills area! aka, castle hill area! though i am over the northern beaches a fair bit seeing my mates etc..
cya!! Garth
https://www.sau.com.au/forums/topic/186276-my-gtr-rebuild-is-done/
Hahaha finally bro.. After a lengthy 8 months.. lots of hard work.. got it done bro..
It was crucial the last minute touches we did before it was sent off to Race Solutions for the tune in :laugh:
Water leaks here and there.. Had mad fun.. wont forget the day we pulled off half the engine just because you
"forgot" to bolt some screws hahaha well done mate.. look forward to cruising with ya..
here are some pictures guys:
Enjoy!
hey all! firstly thanks for the piks al! cheers mate!
and yes my avatar pik is way old now! but i love my old 32, hahahaha!
run in will be about 1000kms, then up the boost to around 16, for another 1000kms then i will go for the big number providing all looks well when its on the dyno.
yes this motor grenaded after a drag meeting. i bought it off a mate of mine grenaded! so i did all the hard work, but now its sounding tough!! hahaha! cannot wait to run he elusive 10sec 1/4mile... and then hit the track in it!
as for mods list:
rb26 block
33gtr crank
stock rods shot peened, linished and balanced
acl black face bearings
arp rod bolts
cp forgies with double spiral locks
genuine nissan head gasket
n1 oil pump
stock head
mild porting
stock valves and springs
new stem seals
tomei poncams 260in 260ex 9.15lift
arospeed adjustable cam gears
n1 water pump
spiltfire coils
iridium plugs
720cc sards
garrett 2860r-5
100mmm cooler
koyo radiator
power fc
air diversion plate
in the process of doing the fuel setup now!
theres probably more in the mods but people will get the idea of whats going on with the motor now!
so yeah, shall be good!
will post more piks 2morro or wednesday, when i get the camera back from my old man!
cheers all
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
