Hey all
was out and about spitting it today when I was pulled over the by the boys in blue, or should I say, the boys in their bacl xr6 sedan with ford sticker on windscreen and frangipannies flowers on rear window. Anywho, got the general defect notice for a BOV not being plumbed back, its a dual port, one side is plumbed, other was vented today, no big deal. then he also notes on the defect sheet that i have had the "front metal bar removed to allow fitting of an intercooler". i was like, "ok?". when got home I was having a look around the front of my car to see what he was smoking, and could not work out what he is on about. I looked at my mates silva with std front bar, and i notice no difference at all. FMIC is in same location as it would be if std bar was fitted to my car, there are no cut marks or anything. FMIC was professionly fitted. there is nothing that has been cut or anything. Was this cop just making something up to get me for cos everything else is legal, or is he being legit?
Edited by Spooner
https://www.sau.com.au/forums/topic/186316-got-defected-today/
actually your be quite surprised but the 2 blokes in the frangapanni stickered xr6 know what the f**k they are on about.
and chances are you ARE in fact missing the piece of metal that goes in behind your front bar, it runs around the top lip below the headlights and behind where the numberplate support normally is.
for the record i was defected driving home from work the same way i drive every other day. so you dont have to be out at the spit to meet these 2 blokes.
heres one prepared earlier.
i know being at the spit isnt why I got i got defected
so that bar in the pic you put up, is that what I should see if I remove my front bar? I need to go look at a std 33 hey. im not saying for sure he is making it up, he must have some grounds for issueing a defect, but I jus cant see where it would go
well well. what can I say. after searching many many threads, in many many forums I came across a DIY fmic install on a s2 r33. i then decided to go do what the police offer did not, and actually have a look for this "metal bar" that had been "removed". and it actually is still there, and given the fmic I have, the bar isnt even cut. so all I need to worry about is sorting the vented side of my BOV. yay. i knew something wasnt right. anywho. all good
Hey Will, ther series 2 front reco is different to series one due to the different design of the front bar.
The pic that James posted above isa series 1 reco and does not look like mine and will not look like yours either, however that said you have two little holes in your bar either side of the number plate yeah? Well has someone cut the reco out behind these holes so you can see straight tho??? Cause the stock S2 reco is solid and does not have any holes in it (near your number plate).
So can you see straight through those hole either side of your number plate, or is there solid metal right there blocking those holes?
Cause if thats the case and you can see right through, then the reco has been cut and yes they can defect you for that.
good question Col, will have to suss it out me thinks. cheers for the heads up on that
Col, The series II reo is thin and sits above the numberplate area...so it generally does not get in the way. However the bar has a plastic bit which usually has to be cut out.
No where I am confused is, when you asked "is there solid metal" either side of the number plates? if my memory serves me right, there is nothing in that area of a standard SII....
Yeah I think pictures are easier to describe that words...
But I mean the little cut outs (in the plastic) in his bar either side of the number plate...
If the reo has been cut behind these holes to let air through then thats what the defect would be for...
if thats the case I should be sweet as then, cos he didnt even look at the front. he looked down between the front grille and the bonnet catch and decided I had no reo bar.
Technically the BOV is illegal and legal at the same time. The venting part is ok. However the venting crank case emissions isnt. End of the day dude, its not that big a deal. Just get the prob fixed so you cant be done again.
yeh bov is sorted. hav jus sealed off unplumbed side. all good
i thought the series 2 reo was the same as the series 1, but the r34 (and gtr) was different and lot of people just substitute them over.
i know my mate had to cut his series 2 bar to get his cooler in and the hoon squad just made him weld a reinforcing plate onto it to strengthen it up. i will ask him exactly how much his had to be cut.
they def seem to be diff between S1 and S2. the S1 seems to have two rows, where as the S2 is just one smaller bar running right in behind the std bar, cant be seen by looking straight at it or fromt the top. i had to get down on my back and shine a torch up to see it
yeh suss out what the go is with ur mates, but i cant see where mine has been cut anywhere, and the cooler is on a slight angle
yeh i think I should be fine hey. funny thing happened today. I called the police station to arrange an appointment as per the official qld police issued defect notice, and they kindly told me they dont do appointments, and i would just have to go down and see what happens, no guarantees they would look at it there and then. no wonder qld police are getting a bad name.
