Just installed my new nismo super coppermix clutch, and its got a very light pedal feel to it(i bought a nismo large slave), but its really on/off, i mean once its disengages, it just catches and goes, and i have to be several meters away from the car infront to make sure i dont hit it, its good for launching, but traffic is a bitc*, does this sound normal???, and anyway to make the clutch feel more progressive?
normal as far as I know....mine is the same..u get used to it.
in the same boat....from stock clutch to twin plate....but doesnt take too long to get used to.....but its pretty embarasing stalling a gtr...
A friend of mine with a Nismo twin plate of some kind says all Skyline drivers should stall at least once every time they drive the car.
Man up people!
My OS twin is very aggressive, but I expected it to be. I just give it two quick blips before I take off to ensure enough revs with the lightened flywheel and off ya go. Interesting up hill in the wet, but apart from that it's all good :P
Lol. i used to have an OS twin plate and was quite pleased with myself if i made it somewhere without stalling. I was a happy boy when i went back to a single purely as i wasn't worried i was going to stall every time i pulled away. I think i've stalled less in the last year than i did in my best week with the twin plate.
Interesting..
I drove a mates OS twin and found the pedal lighter than my single and had a more progressive/smoother take up. Yes the take up was super quick and was easy to stall but I found it easier to drive than my at the time new 9puk Xtreme XHD.
As the 9puk got to half its life it was almost like a normal organic clutch in its feel where as the OS is still nice tight and grippy.
i actually went from a TS2A to a 9 puck XHD extreme :) After the twin plate the single was a joy to drive and was about the same weight as stock. Still doesn't slip on me and still nice to drive
I went from stock to HD organic then to XHD 9puk.
The XHD felt 2x the weight of the HD and the HD was basically the same as stock.
I'm very keen to see how this GTR exedy pressure plate stacks up as I believe its up around 1500kg vs the 1180kg of the XHD I bought back in late 04.
I went from stock to an os giken twin plate and stalled straight away. I got so used to it an loved it after a while.
Now i have a JIm Berry clutch of some sort and it's a single plate. I hate it after about 4 days of driving it. It's too light, it's too easy(sounds good but it ain't) to drive and i hate not having a lightened flywheel now. I feel like i'm driving my sisters charade. I have a feeling i'll be going back to a twin plate soon.
I'm looking at buying an ORC 709D.. what do you mean by menace?
well some people have it and reckon it's easy to drive. they reckon mine isn't installed correctly...
it's actually really light, but has a hair trigger - on or off.
it's only done about 1,000kms, so might get better with some time.
it can be slipped, but I don't get 'used' to it as it get driven about once or twice a month :)
you might like it...
You will need at least 1000k's to break it in....
Then you will need to drive hard every time you see it playing up.
Most of us who use these clutches..whether it be Jim Berry or Nismo drive around in traffic
Once in a while you need to give them a hard time so they come good again.
In your case it is new...take it easy till you bed in your flywheel.
I have a Jim Berry one and I have problems with it when it is cold...bites quick like the way you are saying.
The worst problem is when I drive a standard car for a while then jump into mine...always end up stalling it
on take off the first two times.... :) ...but can't help it..the foot just comes up..not expecting that force.
lol good to see everyone has the same issues.
You only stall it cos you dont wanna look like a tool reving the car too hard, then u look like a tool for stalling it...but you get used ot it and then its fine.
Peak Hour is a bitch...I only drive it on the w/e anyway.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
