with my OS tripple I never stall it, can do hill starts no problem. even with a small 'take up zone' all you need is a small amount of clutch control to drive it easily. so practice up.
i call bulshit!! recall someone stalling when someone took me for a spin... lol
I think you guys need some serious driving practice. I haven't driven a clutch yet I couldn't get the hang of within half an hour.
I'll second that, I never have problems with any clutch after a few starts . You guys think the Nismo twin is bad in traffic........I would have to say its one of the best twins to drive .
The next best is a stocker full face plate but it won't hold much..
I had an unsprung HKS twin plate. The tuner stalled it, the shop owner stalled it and then I did. But I soon got used to it, first day I got stuck in a traffic jam on the freeway...every set of lights was a mini launch. You just have to be more switched on and purposeful in your driving. Sprung center doesn't require much concentration at all
I was helping out at the last SAU dyno day driving cars on and off the dyno. Even Daves tripple plate didn't get me although I was warned about it. What's this thread about again? I forget. Yeah, umm, you'll get used to it.
I my own cars I've had standard, nismo single, heaving duty exedy single, OS twin (solid centre) OS tripple (solid centre) and quickly adapted to all of them. I've also driven tilton twin, carbon single, and various twins, singles and tripples.
i agree with you, but the single plate i had in my rb20 was with no exageration 100 times harder to drive than my os twins and the os twins were harder to drive than the os triple.
actually the os triple is real easy to drive for a big hp clutch
definately hard core singles are much less friendly that hard core twins and tripples. basically to get a given single to hold the same power as a given twin you need a much higher clamp force in the single (as you are working with half the surface area) so hard core singles are generally the worst.
Fits my experience.
I still fight with the JB Full Monty in my GTR.
Jumping from car to car to 4wd etc and then get into the GTR occasionally - bastard red faces me every time. You try to be quiet/gentle taking off in traffic and it is easy to stall. If rolling ever so slightly its fine and you do get used to it again fairly quickly. I have noticed it is not a clutch to ride as it glazes quickly and needs a bit of harder action to clean it up. Can launch like a rocket though.
Just need bigger sunglasses and darker tint on the windows. lol
well some people have it and reckon it's easy to drive. they reckon mine isn't installed correctly...
it's actually really light, but has a hair trigger - on or off.
it's only done about 1,000kms, so might get better with some time.
it can be slipped, but I don't get 'used' to it as it get driven about once or twice a month :(
you might like it...
If I drive my GTR often, the ORC twin plate is great. It's only when I'm not thinking that it bites me.
The most annoying part about it that's dificuilt is that the friction point is more than half way out on the clutch pedal.... so you have to keep releasing your foot to almost the end of the pedal travel. That makes it hard to find and hit's as a surprise sometimes.
If it was closer to the firewall, it would be so so so much easier.
However, I've fallen in love with the clutch and wouldn't go for anything else now.
yeah i found this was the biggest issue, you slowly bring it up... and up... and up... then POW!
update guys: im getting much better driving these twins now, only hill starts are a bitch, i just take my time hahaha. I wouldnt go for anything else in saying all this, as when it catches, it catched hard, and i love it, im so used to stalling the car, its become 2nd nature on the street, but yeh im down to about maybe once every 3 days?....getting there slowly:)
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
