Removing Harmonic Balancer But .........
Hi All,
Need to remove harmonic balancer mmm,
Ok Ive tryed cranking if with the engine bar against the ground no luck,
Tried with my ratchet gun increased the air pressure from my air compressor no luck,
I didnt have the car in gear 4 or any gear for that matter (will retry with car in gear also with a bigger battery more cca) but i dont have a tailshaft to connect to to the diff to give more resistance for the crank.
If someone has applied lock tight to the bolt, will it need to be heated to remove??
Will only locking the gearbox inplace create enough resistance to break the seal that this stupid bolt is in lol
or will i have to wait for the till i get the one piece tailshaft back!?
Thanks all
Peter
https://www.sau.com.au/forums/topic/186334-removing-harmonic-balancer-but/
Hello Peter,
I'm in the process of changing my son's timing belt tonight on his 1989 R32 GTS RB20 manual. I put the car in 4th gear , handbrake on . Used a 27mm socket and breaker bar. It come undown quite easily. So yes I think you will have to positely lock the engine somehow. I did read an article where this guy wrapped a peice of twine around the crank pulley and the alternator pulley. I'll see if I can find the picture. It may be of some help. I then tapped out the two 6mm bolt holes in the pulley and used a puller to remove it.
Regards
Brian
Hi again
Found the web site
http://www.skylinegts.co.uk/index.htm
Then go to service and maintain first choice on the top of the page - fiiting a new cambelt to R33
Hope this helps
Cheers
Edited by brtnrt
Hi, u should be locking the flywheel...
Take off the starter motor, and put the flywheel lock in (if u don't have one use a large screw driver, put it in the flywheels teeth, when u start to undo it, it'll lock in) <-- that's how i did it
Hi,
Thanks guys i read the uk site today and also looked at dumpin the sump to lock the crank with timber ill do all in the most easiest way lol and leave the sump for last i never thought of lockin the flywheel cheers for that and for both you replyin so fast need someone to make a sticky on this with all opitions from hardest to easiest not just the easiest way lol
Again thanks heaps
Peter :laugh:
Edited by INFRNT
